bobzilla2009
- Oct 7, 2009
- 455 (0.08/day)
System Name | Bobzilla the second |
Processor | AMD Phenom II 940 |
Motherboard | Asus M3A76-CM |
Cooling | 3*120mm case fans |
Memory | 4GB 1066GHz DDR2 Kingston HyperX |
Video Card(s) | Sapphire Radeon HD5870 1GB |
Storage | Seagate 7200RPM 500GB |
Display(s) | samsung T220HD |
Case | Guardian 921 |
Power Supply | OCZ MODXSTREAM Pro 700w (2*25A 12v rail) |
Software | Windows 7 Beta |
Benchmark Scores | 19753 3dmark06 15826 3dmark vantage 38.4Fps crysis benchmarking tool (1680x1050, 4xAA) |
I currently have a wireless n network with a 50mb connection. At the moment i can download at around the 3-4.5MB marker over wifi. If someone else is using the wifi at the same time will that lower that download rate even though there is more isp (and router, technically) bandwidth to spare?
Basically the question is that whether or not the the overall speed of the wireless is shared fully across computers or whether or not there is some degree of overlap, where two computers can use more of wifi networks potential than just one as long as it is within the bounds of the rated wireless speed and ISP speed.
