be quiet! is expanding its gaming mice and mechanical keyboard lineup by introducing the new Dark Perk Sym and Dark Perk Ergo mice, as well as Dark Mount and Light Mount mechanical keyboards. be quiet! also the new Project Light Base Stand, a custom-designed accessory that adds a fourth orientation option for the Light Base 900 FX chassis.
The be quiet! new gaming mice bring high-performance and premium design, combined with full configurability, and it is obvious that company is trying to cover as much base as possible since the Dark Perk Ergo is a right-handed mouse while the Dark Perk Sym features a symmetrical layout for ambidextrous use. Both new mice share similar specifications, including 55 g weight, the Pixart PAW 3950 32,000 DPI sensor, 8000 Hz polling rate, and precise optical Omron switches. These are wireless mice that promise up to 100 hours of usage time. be quiet! also showcased its new Dark Mount and Light Mount mechanical keyboards, and this is the company's first entry into the gaming keyboard market. Both use triple-layer sound dampening, aluminium top plate, proprietary silent switches that will be available in linear or tactile versions, per-key RGB illumination, and more. The Dark Mount uses a modular construction with unique Media Dock, while Light Mount aims for a more minimal design with an integrated Media Wheel. Both will use be quiet!'s IO Center software.
be quiet! was also quite keen to show off its new Project Light Base Stand, a custom-designed accessory that adds a fourth orientation option to the Light Base 900 FX PC case. The Project Light Base allows users to angle the glass top panel to the side and orients the exhaust side of the case down, making it much presentable and giving a better view of the internal components.
The Dark Perk Ergo and Sym mice will be available in August 2025, priced at $129.90 / €129.90, while be quiet! has yet to finalize the price and availability date for its mechanical keyboards or the Project Light Base Stand.
