Best way to remove stripped screw?
3,051 (0.60/day)
System Name The SwagMachine / The Sister
Processor Core i5 3570K @5.2ghz 1.3V/ 1100T
Motherboard ASUS P8Z77-V / ASUS M5A99X EVO
Cooling Phanteks PH TC14PE / Corsair H40
Memory M379B5273DH0-YK0 2X4GB + PVI316G213C1QK 2X4GB / 2x4GB Patriot 2133
Video Card(s) PNY 780Ti /Windforce 7950
Storage 2xSamsung 840 EVO 250gb+WD10EZEX + WD30EZRX/ 1x WD1500 Black
Display(s) AOC Q2963PM+Acer S200HL / Acer S200L+ LG 22LD350
Case Fractal Define R4 / NZXT Trinity
Audio Device(s) Asus Xonar DG / Asus Xonar DG
Power Supply Seasonic 750X / ROSEWILL RG630-S12 630W R
Mouse Razer Deathadder Chroma / Roccat Kone+
Keyboard Razer Blackwidow 2013 Stealth / Roccat Isku
Software Windows 8.1 Pro / Windows 7 Ultimate
Benchmark Scores one time I scored a 3 on 3dmark 11
I have a majorly stripped screw on my side panel, I've tried everything I even drilled a bit into the screw. Does anyone have any ideas of how to remove it?
I can possibly make a few suggestion's but would be nice to see a pic of what you're workin' with :o
3U7Yv.jpg1
Best I could get it :(
take some vice grips and try pulling/unscrewing at the same time just so you don't damage the threads in the screw hole.
I've tried that too, there isn't enough of the screw sticking out to get a good grip :(
All i see is a red X :o If you have a Dremmel you can make a small slot and use a flat head screwdriver.
Pic is showing up now, if you have a good star driver you can try to apply a pushing force (push the driver into the socket) while turning, that may get it to move :o If that doesn't work and you can't get to your Dremmel you can make a slot with a hacksaw or file
Sorry, I re uploaded this pic :) I do have a dremmel, but it's at the house me and my father are working on, an hour away...
1./ Try putting a rubber balloon over the screwhead then using the driver. It might give you extra grip.
2./ Use a screwdriver or bitset that allows a wrench to be used for more torque http://pad2.whstatic.com/images/thumb/7/72/More-torque-Step-3.jpg/629px-More-torque-Step-3.jpg
3./ If you have a dremel or small drill, drill out the centre of the screw. It will reduce friction on the thread and it will come out easily
4./ Can you use pliers on the reverse side (screw thread)?
NEXT TIME use the right tool for the job! This is a PZ screw that you have ripped using a PH driver!
Can you get at the back of the screw? If so, try to give it a little nudge/twist from the back to loosen it and then try to get a flat head jewelers screwdriver to turn the screw out.
If that doesn't work there are more options
I haven't heard #4 yet, I'll try that! It wasn't that I used a diffrent sized screw driver, I just tried to force in the screw even though it was too big.. :o
If this is for the fan, take out the other 3 and twist the fan off of the screw slightly....
You may be able to keep the screw from turning by applying pressure against the panel with your screwdriver.
All you need is a 1/4 to 1/2 turn and it will get easier to deal with.
:( I don't think I can wait a week and a half for it to come in the mail.. I also tried the pliers on the back of the screw, and theres not enough screw showing to get a good grip
Not necessarily that exact item or vendor, just an example.
Do you not have hardware stores near you?
These plus what i mentioned in my last post (i ninja edited in case you missed it) are prolly your best option's. The key is to be patient while doing it or you can bugger it up even worse! Trust me i have buggered my fair share of screw's/nut's/bolt's :o
Best ways to remove these damn cheap screws are to use a plier or something that you can tightly take a grip of the screw. Then start twisting the direction that you normally would to remove the screw.
the link that Arctucas posted is the right tool for the job, Check lowes or home depot both carry.
I think this is for the side panel fan- cheapest, easiest way out is just to cut off the corner of the fan and melt the plastic off the screw with a lighter (carefully) or drill around the plastic until the screw is exposed.
Remount the fan w/3 screws or replace the fan... this will save the outside finish from damage.
if its a philips or posi it should be a piece of cake to drill out its centre
if that dosnt ease its removalm drill the screw out with a wider bit, simples and easy ive done this lots
Yes drill it out. Chose a drill bit that is almost as big as the threaded part of the screw and go to work on it.
Thanks for all the suggestions guys! I ended up just drilling it, and with a little work the screw bended in on it's self and I could pull it out! Thanks for all your help :)
jb weld your screw driver to the screw. let it sit over night, then it should unscrew.
Right on! Glad you got it sorted :)
LOL you're a funny guy, if I had a welder, many things in my case would look different ;)
Lawl too late :( the area around that screw is scratched to shit... It make me want to just powder coat the entire case even more..
