Big Problem With Msi K9a2 Platinum.help Me Help Me!!!
fabgat55
4 (0.00/day)
I have a system with mainboard MSI K9A2 PLATINUM with AM2+ Phenom 9600 BE.The big problem is that i was 't able to install wiondows vista ultimate or Home premium 64 bit.i was successfull to install windows xp 32 bit and also install software to see compatibility with 64 bit and everything is ok
At boot show the whithe line '' windows is loading files'' and after finishing appear only black screen and computer is frozen stutus.no overclock is put on computer
my computer is:
amd am2+ 9600 BE
mainbord MSI K9A2 platinum
2x2Gb ram 800 TEAM 5-5-5-15
hdd maxtor diamondmax22 500 gb 32 mb buffer
Power 650 watt enermax infinity
pioneer DVD/blu ray reader/writer
Graphic card ATIsapphire 3870
really help me ...i will give 5 euro with paypal to evryone solve my problem
Namslas90
4,846 (0.71/day)
Earth
Probably a memmory Issue; a lot of 2GBx2 or 2GBx4 kits are not supported especially with Phenom and Vista 64-bit on that board.
Try flashing the BIOS to version POH, users have found it solves Isues with Vista and 2GBx2 or 2GBx4 memmory kits.
http://www.box.net/shared/gsn4mgt6o4
Be sure to load defaults and then flash with parameters /p /b /n /c.
******CAUTION******, flashing BIOS can result in damaging your motherboard, follow instructions carefully.
fabgat55
4 (0.00/day)
what means paraters?
what means flash bios with parameters /p /b /n /c?????
can u explain me better
thank u very much...i was grateful for all life if u solve this problem.......and also give u money promised ....
Namslas90
4,846 (0.71/day)
Earth
I suggest you study up on BIOS Flashing, and be sure you are comfortable with the proceedure before continuing. Or maybe find someone that can help with with this "on-site".
It's easy to make simple mistakes when flashing BIOS....also be sure to "Back-up" your BIOS before flashing.
Don't need the money, maybe use it to hire someone to flash the BIOS for you.
fabgat55
4 (0.00/day)
flashing bios
the file that i dowlnoad fro teh link is a rar file.rar reader wasn't able to open i don't understand why?and then i must flash bios from floppy disk or program live bios update ?
where i must puit parameters?
thank u very much
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
thank u very much
because the bios file is in a type( .rom/.bin) that only the bios chip or programming apps can read! Extract the folder and use the file inside to replace the file on you bios as Namslas was leading to!
fabgat55
4 (0.00/day)
problem
the problem is that u can't exstract because stop u..the file is a .poh file not a bin or rom...u have other link to download or i make a mistake to exstract it??
thank u very much
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
yes you are correct on the .POH Must be a MSI thing. I got the rar on my desktop and I opened it and saw the .POH file. use that file, just move it from the floder its in to desktop. then set it to whatever you plan to flash with.
No offense here, but you sound rather new to this....maybe you want to get a local PC shop to show you how, or a friend to help?
There are dangers involved in flashing a BIOS and it can leave your mobo useless if not done correctly.
BumbRush
225 (0.04/day)
vista 64 wont install with over Xgb ram, such think it was 2gb ram , go down to 1 gb install and update vista, then put the extra ram back.
