Bios .bin instead of .rom
jaeestrada
7 (0.00/day)
This may be easy to answer.
In the vga Bios Database of techpowerup, the bios' are listed and uploaded as .bin files but the tool (nvflash) to upload and flash a card requires a .rom file?
just wondering what I should do at this point.
Thanks!
I think GPU-Z saves it as a .bin file, but yes, needs to be a .rom file for nvflash. Simply change the extension to .rom
Just a blurb, not sure what you're doing, but it's wise to always save a copy of your card's original bios. It's easy to capture using GPU-Z. Ask if you need help..
Your right!
Thanks for the tip,
