BIOS Flashing Help
7,336 (1.12/day)
C:\Program Files (x86)\Aphexdreamer\
System Name Unknown
Processor AMD Bulldozer FX8320 @ 4.4Ghz
Motherboard Asus Crosshair V
Cooling XSPC Raystorm 750 EX240 for CPU
Memory 8 GB CORSAIR Vengeance Red DDR3 RAM 1922mhz (10-11-9-27)
Video Card(s) XFX R9 290
Storage Samsung SSD 254GB and Western Digital Caviar Black 1TB 64MB Cache SATA 6.0Gb/s
Display(s) AOC 23" @ 1920x1080 + Asus 27" 1440p
Case HAF X
Audio Device(s) X Fi Titanium 5.1 Surround Sound
Power Supply 750 Watt PP&C Silencer Black
Software Windows 8.1 Pro 64-bit
:(Man, I am so pissed. I can seem to get ATIFlash to work while I Boot from dos. I have tried everything and have read everything and I can't manage to flash my HD2900 's BIOS. Please help me, I am tired of googleing. This is what I have been doing, I open up the DOS ISO file and then add all of atilfash's utilitys and a few BIOSs'. I boot fromt he CD and I get in to dos but whenever I type atiflash -p 0(zero) -newbios 12v.rom -f to flash it I just get command or file not valid. I have tryed sverel way of wording that nothing works, I'm a real noob when it comes to flashing so anyone who can help would be great.:)
i think u should type "atiflash -f -p 0 biosname.rom" without the "..im already flash both my hd2900xt to change to higher clock to 880 core 950 mem...and its work...unfortunately its not stable..so i flash to original bios back :(
try using ati winflash instead, flashing form windows is a lot easier.
I' not sure how to use that either, trying atiflash -f -p 0 12v.rom right now, will report back soon.
Sorry, that didn't work as well. Might I add that when DOS is loaded, all I get is this A:\> Is that what I Should be seeing or should I be seeing atifasher loaded up or sumtin?
Flashing BIOSes in Windows is nutoriously risky. I wouldn't reccomend this.
Didnt I read somewhere that Dolf made a simplified BIOS flash utility for this specific card?
I'd search the forums, hell it may even be in the thread Namslas posted not sure and didnt read the whole thread he linked!
yup was in the last post of that exact thread...try this...http://forums.techpowerup.com/showthread.php?t=43702&highlight=2900pro
yeah I Know about that, thats what I used to flash my pro to an XT. However I am look to flash my XT to a BIOS that has 1.2volts or 1.35 volts. Now you know how I managed to flash before but can't now. Thanks guys for helping out, I just need to figure out what I'm doing wrong.:confused:
can i know what bios r u trying to flash??and where did u get that?
Well I can give you 2 out of 3 on that question.
-f is forcing the flash
0(zero) is the device ID if there were 2 cards in place to flash card #2 it yould need a 1 in place of the 0
As far as the -p goes , its been too long since I flashed my X850XT to PE to remember, but I bet some screenshots of Atiflash from google may explain its use!
So with the same parameter i can flash my hd3870 with a modded bios? Winflash does not works because of the bad crc of the file (i edited it with hexedit to modify gpu frequency and voltage).
Thank you.
Bye
As far as I know all bios to this point have used the same command line when flashing with ATIflash in dos....Cant say for certain tho with the 3870 , its just an assumption from me that it would be the same.
