BIOS saving problem with GPU-Z 2.8.0
  • Thread starter Thread starter Deleted member 110753
  • Start date Start date
Hi Guys,
I don't understand why the BIOS saving killed my display !?
The bottom half part of my screen was flickering and only an OS reboot solved the problem.
Is it a bug or a known issue ?
Hi Guys,
When it saves the bios it may be disabling the adapter for a moment and for whatever reason that may be what's causing the issue . But im basing that guess on the assumption that gpuZ is momentarily disabling your adapter.
You're referring to the little arrow pointing to the right on the main screen correct?
Edit*
I was correct, it disables it. I just ran it ,and it worked flawlessly....might be a issue on your end, but luckily a person only needs to save their bios a time or two, but its definitely odd. does using either the submit, or save function after clicking the arrow offer a different result?
Yes, I used the little arrow to save the BIOS.
This card is new on one of my PC's, but I never got this issue with my other PC's...
