Biostar Tforce6100-754 vs Coretemeter.exe which one should I trust for CPU temps?
6,788 (0.92/day)
Republic of Asia (a.k.a Irvine), CA
System Name ---
Processor FX 8350 @ 4.00 Ghz with 1.28v
Motherboard Gigabyte 990FX-UD3 v4.0, Hacked Bios F4.x
Cooling Silenx 4 pipe Tower cooler + 2 x Cougar 120mm fan, 3 x 120mm, 1 x 200 mm Red LED fan
Memory Kingston HyperX DDR3 1866 16GB + Patriot Memory DDR3 1866 16GB
Video Card(s) Asus R9 290 OC @ GPU - 1050, MEM - 1300
Storage Inland 256GB PCIe NVMe SSD for OS, WDC Black - 2TB + 1TB Storage, Inland 480GB SSD - Games
Display(s) 3 x 1080P LCDs - Acer 25" + Acer 23" + HP 23"
Case AeroCool XPredator X3
Audio Device(s) Built-in Realtek
Power Supply Corsair HX1000 Modular
Coretemeter.exe gives me CPU core temps. The mobo under windows show different. Used Biostar's software and Everest both display the same. But if I re-start and go into Bios it shows a different temp. Bios temp > Everest Temp by 5C. The bios temp and core temps are close enough (Bios<Core by 2Cto4C). So Everest<Bios<Coretemeter as 29C:34C:36to38C
Which one should I keep an eye on
Coretemeter
Bios
Everest
Motherboard Monitor doesn't support my mobo. Anyother monitoring software that will log me temps and gives me correct readings?
Athlon 64 3200 @ 2574(234*11), 1.55V 38C idle, 52C load. Cooled with Thermaltake RX-k8 heatsink.
Advise please.:respect:
personally i take them all into affect when looking.....but if u use the highest 1 as a gague for temp, you will always be safe. coretemp does run hotter on most machines than in bios or onboard utilities. but as i read i think its cuz it reads the actual core instead of the mobo sensor chip!
