First off, here's my specs:
P4 3.0E HT
Intel D865GBF (P24 BIOS) Mobo
350W PSU
2x512 Kingston ValuRAM DDR400 (Single Channel)
WD Caviar 80GB 7200RPM PATA
ATI Radeon X850 Pro (499/499) -> XTPE (540/587) w/ ATI Catalyst 5.13 (orig)
Samsung 713v Monitor (1280x1024 70Hz 32Bit)
SB Audigy 2 ZS
XP Pro SP2
I recently (yesterday) installed the Zalman VF700 AlCu VGA Cooler on my card. The installation went pretty well, although I have doubts about my installation prowess. As soon as I got the cooler on, I flashed my BIOS to the ATI AGP XTPE using the modified flashrom. I tried to run 3DMark05 after doing the flash, and during the 2nd Game test the screen went blank and my PC stopped completely, although it was still on. It din't respont to any commands. I reset it, then tried to run ATITool to detect Max core. The same thing happened, ATITool reported an error at 654/587. I reset again, then I tried to use ATITool do an Artifact Scan. In like 2 seconds everything became unresponsive again, with the blank screen.
Here's my idle temps for CPU and GPU
Processor - 50
System Zone 1 - 38
System Zone 2 - 44
GPU/GPU Environment
min - 39.1/35
max - 39.3/36
avg - 1.$/35.8 <-Don't know why [1.$] is coming up in ATITool
I have a generic CPU fan, a front 80mm intake fan, and a rear 80mm exhaust fan.
It could be a power issue. I split the molex going to my card because I needed another molex connector for my VGA cooler. But I'm not sure.
Edit: Nope, sorry. CIV doesn't work. For some reason it din't freeze the first time I played it. Other games don't work either.
P4 3.0E HT
350W PSU
SB Audigy 2 ZS
XP Pro SP2
Processor - 50
System Zone 1 - 38
System Zone 2 - 44
GPU/GPU Environment
min - 39.1/35
max - 39.3/36
