[Case Gallery] Blue Skull Project (Updated)
  • Thread starter Thread starter foxthemad
  • Start date Start date
F
foxthemad
Specs:
Lian Li PC-7BYCF >> Gigabyte EP45-EXTREME >> Q6600 @ 3.2 >> 4Gb Mushkin DDR2 800Mhz >> Asus 4870 512Mb DK >> CM Hyper 212 >> 4x120mm Blue Led Fans >> Enermax Infinty 720W >> 2x1Tb HDDs
Mods:
I made holes in the MB Tray for better wire management, white powder coated, custom top side for 2x120mm fans with grill, skull engraved side panel, and a front skull. The skull is hand made by a good friend. The design is the same as the engraved one.
The front skull is still a work in progress. It still needs a paint job and some of the grill behind it taken out :)
Very clean build. I love it :D 9/10
I like what you've done with the Hyper212 mate.
Wicked cable management.
Thanks guys. I am glad you like it. This project is not yet finished, but for now I managed to achieve (finally) what I wanted.
From now on time will not be an issue, but be sure I will give updates.
The way you have stuff arranged makes it looks very spacious on the inside. I've been thinking about getting a design sandblasted into my window, maybe some sniper cross hairs or something since it's the Sniper.
Well if you have where to do it, go ahead and do it. It will bring a cooler look to the case that's for sure.
All the best.
very clean, lot of progress than before..very good job there mate..8/10
love white pc's
i love the color scheme, that alone is 10/10 for me :)
