- Apr 24, 2012
- 60 (0.01/day)
- Bournemouth
Processor | i5-3570k |
Motherboard | GIGABYTE GA-Z77X-UD5H-WB |
Cooling | Be Quiet Dark Rock PRO BK016 |
Memory | Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz |
Storage | Force Series 3 120GB SSD, WD 3TB HDD |
Case | Fractal Design Define XL USB3.0 Full Tower Case - Black Pearl |
Power Supply | Corsair HX750W |
Software | Windows 7 64bit |
Hi people...
I completed my fist build a month ago and everything was going well.
Now when i go to start the computer it gets past the motherboard boot screen and goes to a black screen with a flashing cursor at the top left corner. It wont allow you to type or do anything, then only way to get into windows now is to restart and click F12 and select the boot drive and then it loads.
The first thing i thought was i need to change the boot option in the BIOS, which i did and saved settings and restarted. This time it loaded and thought i had solved it, but the next time i started the same problem again the BIOS wont save the boot settings.
I really need some advice???! Thanks in advance
i5-3570k
Corsair HX750W
Windows 7 64bit
WD 3TB Cavier Green
i5-3570k
Corsair HX750W
Windows 7 64bit
WD 3TB Cavier Green
