bootable backup?? help
digitalhater
110 (0.02/day)
System Name [D]igital [H]ate
Processor Intel Quad Core Q6600 @2,4 Mhz cooled with Asus Silent Knight II
Motherboard ASUS P5E
Cooling 5x Case Coolers, 1x Video Cooler, 1x 2 Fans HDD Cooling
Memory Mushkin 2x2Gb @1066Mhz
Video Card(s) BFG nVidia GeForce 9800GX2 1GB DDRAM3
Storage 1xSeagate 160GB SATA2; 1x Seagate Barracuda 500GB - 7200.11, 32MB Buffer Sata2
Display(s) LG L226WA 22" HDReady LCD Monitor | LG LCDTV 42LG5000 1080p on HDMI
Case Raidmax Smilodon
Audio Device(s) Creative Audigy 7.1
Power Supply Thermaltake ToughPower 600W
Software Windows Vista Ultimate SP1
Hi guys,
This might sound as a noob questions for some of you but I've never done this before and maybe you could help me.
I'm wondering if there is a program or a feature or something that would let me install a fresh copy of windows vista x64, and then install all the drivers and applications I need and after that to do some sort of back-up or something that would let me install it at a later time with all the drivers and software I need.
I mean after a format, to just plug in that new "back-up" and after installation to have windows vista and all the drivers and software I need installed without having to reinstall them manually after installing windows..
Is there such a thing?
Thanks in advance for your help and support!
Best regards,
DH
Uhmm, slipstreaming windows installation disk with additional applications... I think vLite is the answer? I'm not sure but slipstreaming stuff on a new install disk, meaning making a copy of the original disk and modifying its contents to add wanted softwares.
Edit: ^ He beat me to it. hehe :toast:
I i choose to use windows restore, if my windows craks...will I be able to bring it to it's initial state?
Depends on the restor point - Windows restore will will bring your windows to the state it was when the restor point was made. Vista Business/Ultimat has back up utilities, but I never used them.
Nero let's you do some slipstreaming to add wanted software, IIRC most burning software would let you make your own bootable and slipstreamed os installer. But I don't really know how to do it, heh, I just install os and install stuff manually. :D
