booting xp when vista was installed 1st
regan1985
1,449 (0.21/day)
Coventry UNI England
Processor yorkfield core 2 quad Q8200 3.2ghz 1.26v
Motherboard asus p5Q SE
Cooling akasa ak965
Memory Kingston 1066 2x2gb 1104mhz 2.2v
Video Card(s) SAPPHIRE HD 2600 XT DDR3 857/1078
Storage 2X Samsung spinpoint 500GB 7200 4x 1tb samsung eco 5400
Display(s) 2xSamsung P2270 22" Widescreen
Case NZXT Hush Quiet Case in Black
Power Supply OCZ StealthXStream 500w Silent Power Supply
Software windows 7 64
any1 know if there is a command when booting to select the partition xp was installed on, vista was installed first but on the primary partition c:/ xp is on e:/
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
If you didn't install xp to a separate hd, and go into bios to select that hd as the boot device, then xp has replaced the vista boot loader. Normally, I'd use vistabootpro and make it rebuild the vista bootloader with xp on the menu as well. Unfortunately, vistabootpro isn't freeware anymore so now it's more complicated. I suspect using the vista boot disk to do a repair is an option, but you'll probably have to manually add xp to the boot menu.
2,573 (0.38/day)
N.Ireland
Processor Core I5 4440 / 4430
Motherboard Asus z87-k / Gigabyte ga h97- d3h
Cooling Arctic freezer / Generic
Memory 8 gb Mushkin / Various
Video Card(s) Radeon 7850 cf / Gtx 690
Storage Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme
Display(s) Technika 32" / Asus 24` ips
Case Corsair
Audio Device(s) X-fi Titanium
Power Supply Corsair 850 w
You can dl older freeware versions of vista boot pro. They get the job done.
regan1985
1,449 (0.21/day)
Cooling akasa ak965
its on a laptop so only had the choice of install on the same HD, also xp worked fine then i couldnt boot vista so i reapired vista now i can boot xp. is there no way to get the option to boot both?
2,312 (0.34/day)
Norn Iron
Processor Q9550 @3.8
Motherboard Asus Maximus Extreme
Cooling Custom water cooling
Memory 4GB Patriot Viper DDR3 1600MHz
Video Card(s) 2x HD4870 512MB
Storage 2x 500GB
Display(s) 3x LG L226WTQ 22" Widescreen LCD
Case Modded TJ07
Audio Device(s) On board
Power Supply PC P&C Silencer 750
Software Windows 7 Ultimate
3,640 (0.59/day)
California
You can use EasyBCD and then follow this guide.
http://neosmart.net/wiki/display/EBCD/Installing+XP+After+Vista
Read the setting up dual boot and finishing up sections.
+1
I used this, and it worked well.
I got my Vista installed first on my RAID, then I made a partition for my Windows XP, I installed XP, after that I couldn't boot into Vista.
So, I inserted the Vista DVD, use the startup repair, it fixed Vista, I was able to boot into Vista, but then I lost XP. :roll:
So, I download Easy BCD, I add an entry for XP , save it, write it, restart.
Then it's done. :cool:
