Bright Memory: Infinite Ray Tracing Benchmark
1,005 (0.14/day)
Processor i9 10850k
Motherboard Asus strix Z-490-e
Memory G.SKILL Trident Z 4000mhz
Video Card(s) Asus STRIX RTX 3080
Storage 1tb Samsung 970 EVO,1tb hdd,750gb hdd
Display(s) Asus 27" 144htz 1440
Case Lian Li lancool 2 mesh
Power Supply Seasonic GX-850
Keyboard Logitech Pro
Seen this on steam today.
It's free and looks very good.
it has a loop mode at least, i wonder if it can be used for stress testing.
I take it this benchmark is based on the game?
Any other download link?
Says in the screenshot DLSS off, I assume this means the benchmark supports DLSS?
Ryzen 9700x PBO
2x32GB DDR5 @ 6200MHz, 28-36-32-48-80
RX 9070 XT, +10% PL
Win 11 24H2 (26100)
Trying to get a screenshot but it seems to run in exclusive fullscreen without other options to disable, and my tiny keeb has no print screen button... crashed trying to get to the snipping tool at the results screen haha, not sure of best way to get around that, don't want to upload a photo of a screen like a n00b. Result above this post would seem to suggest borderless though.
Honest question: how do you live?
With my mistakes.
I like the keeb but honestly should have gotten a slightly larger one, 60% means no arrow keys and I missed them the most, so now have arrow keys and a volume know in a DIY 3D printed little block next to it. I make it work but no print screen button (and custom keycaps lol so even if there was an ALT/FN + normal button I don't see it) is also a bit of a shite. I use steam screenshots or snipping tool the most.
In any case it was 140fps at 1080p RTX V high DLSS off but till I get the screenie that's not worth a lot.
Gonna need to add PRTSCRN to that!
Funny thing. Saw that thread got resurrected wanted to try the benchmark to see how 5080 will perform, but apparently it doesn't support RTX as said by benchmark
It does, I just ran it multiple times, only issue was a skill issue on my part for getting a screenshot of it.
Have a phone pic I guess, slightly lower that my original run which netted 140fps.
Alt+Enter for out of fullscreen.
Funny thing. Saw that thread got resurrected wanted to try the benchmark to see how 5080 will perform, but apparently it doesn't support RTX as said by benchmark :roll:
It's strange since you see that Wolf did it with the 5080.
____________________
I have some old screenshots to add here as well.
Well after second start it actually recognized that my GPU in fact supports RT.
Had to do a pic from a phone as well, as W11 atleast in 24H2 uses snipping tool for prtscr so it crashes when you try to take a screenshot.
Also crashed two times when trying to run 1080p so overall unstable demo.
Try the windows snipping tool, you can delay the screenshot a few seconds, alt tab into your game, and magic happens
MBA 7900XTX with stock settings:
I had no problems taking a screenshot through either RTSS or PrintScreen in Win10.
@AVATARAT Your 9070XT is 34% faster here :D
And an oc'd 6600XT :pimp:
Guys, the game is on STEAM.
Just use F12 if you have overlay enabled. :D :D :D
Almost forgot about this game. Played it awhile ago, though I'm not sure if it's even viable as a benchmark. With RTX it was a bit unstable, plus you get the usual object pop typical of unoptimized UE games. I don't think those and other issues were patched out at either point.
But as a game - it was fun. Kinda like a waifu-themed painkiller with combos and superpowers. Arenas were decent, but achievements were broken.
It was heavily promoted as "being developed by a single person", but after seeing end-game credits 4 or 5 times I kinda think they oversold it.
MBA 7900XTX with stock settings. I can't adjust the DLSS setting, but the config file confirmed 100% resolution scaling:
I change it using the arrow keys on the keyboard.
I use snipping tool for screenshots too :)
Had to roll back to 566.45 to run this -- instant crash at the start of the run with 572.70. Done with these unstable crap Blackwell drivers.
Ryzen 9700x PBO
Intel Arc B580 +8% PL
Win 11 24H2 (26100)
