Building A Small High Definition HTPC
1,960 (0.26/day)
The Kingdom of Norway
Processor Ryzen 5900X
Motherboard Gigabyte B550I AORUS PRO AX 1.1
Cooling Noctua NB-U12A
Memory 2x 32GB Fury DDR4 3200mhz
Video Card(s) PowerColor Radeon 7800 XT Hellhound
Storage Kingston FURY Renegade 2TB PCIe 4.0
Display(s) 2x Dell U2412M
Case Phanteks P400A
Audio Device(s) Hifimediy Sabre 9018 USB DAC
Power Supply Corsair AX850 (from 2012)
Software Windows 10?
For those too lazy to click
Am planing of building a htpc, and it has to be as small it can get and has to play 1080p smooth and output 1080p out dvi
so this its is what i came up with
here is how the case look like
http://shg.no/documents/wmv/5691_SHG...20_CBR@5Mb.wmv
ok its a show off
Chassis Specs
(W)430mm x (D)270mm x (H)53mm
200W PowerSupply
MicroATX Motherboard
EE CPU (not Extreme Edition but Energy Efficent) or vanilla
System Specs:
CPU: AMD Athlon 64 X2 3800+ Socket AM2 2.0GHz 2x512kB Boxed 65w EE
CPU FAN: Hiper HFC-20820-C1 AM2 CPU Cooler (only 106 x 80 x 35 mm big)
Motherboard: Abit NF-M2 (Geforce6150+nforce430), GBLan, 7.1 surround, DVI-D out
RAM: OCZ DDR2 1024MB Gold Edition PC2-7200 1024MB 900MHz. (5.5.5.15) this might be OVERKILL but hey the price is the same for a ~PC2-5400
TV: Hauppauge OEM WinTV PVR-150 MCE Certified
Case: Hiper HMC-1K53A Media Center Case Black mATX
DVD-RW Slim: any 8x slim DVD+R/DVD-R & DL burner
HD: Western Digital Caviar 250GB, 7200RPM, 8MB Cache, ATA133 (old one, me wants to get rid of it, my gaming rig will be legacy free of pata bs!
HDTV Setup
SONY KDL-40W2000 40" LCD-TV FullHD 1920x1080p, 16:9, 8ms, 8000:1, 2xHDMI
1:1 Pixelmapping via HDMI>DVI
so i should be covered
nothing has been bought yet, including HDTV
Such a small psu... can it handle all of that?
I don't think it will. Not with any sort of high end gfx card. You could always add on an external 12v psu that would be remote switched by the main PSU. That's a hassle though.
