Building Again, HELP !!!!!!!!!
bohica_34613
31 (0.00/day)
Brooksville Fl, just north of Tampa
System Name IT , that thing
Processor Intel Core 2 Duo E6600 @3.2 29c @ 1.28v
Motherboard ASUS P5K3 DELUXE
Cooling Arctic Freezer Pro 7
Memory 2Gb OCZ DDR3
Video Card(s) Sapphire HD3850 512
Storage WD Raptor 74gb 10,000 SATA/WD 250 Gb SATA
Display(s) Acer X203W
Case Coolermaster
Audio Device(s) Onboard sound
Power Supply Thermaltake 600w
Software XP PRO SP2
OK, I need some help.
My puter is working fine but need more memory, anyway I just got a call from a friend and she said she wants me to build her a puter. She was talking about buying from a store at first but changed her mind. She's working with a $800 budget so I'd like to hear some ideas from everyone about what she can get.
Thanx
bohica :toast:
what will the computer be used for?
She likes to get on here to chat and play the pogo games and is playing Hellgate on my puter so she'll probably want to play it on hers after I get it and put it together.
Thanx for the links.
She already has a 250gb HDD so that's not needed, don't need monitor - keyboard or mouse either
np... if you can go a little over 800 you will have a vary nice rig for her. :toast:
newegg'd:
Intel Core 2 Duo E4500 Allendale 2.2GHz LGA 775 65W Processor Model BX80557E4500 - Retail 124.99
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - Retail 94.99
GeIL 2 x 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) GX22GB6400UDCA 79.99 - 40MIR = 39.99
OCZ StealthXStream OCZ600SXS ATX12V / EPS12V 600W Power Supply 89.99 - 15MIR = 74.99
GECUBE GC-HD3870XTG4-E3R Radeon HD 3870 512MB 256-bit GDDR4 PCI Express 2.0 249.99
total = 639.95 - 55MIR = $584.95
add OS in there? case?
i guess since its only 584.99 you could use that extra cash and up the video card a bit or something. unless she doesnt want to spend anymore
newegg'd:
thats probably what i would go with to
you can get a WD or samsung 500 gb hd (i own from both companies) for about a $100 bucks also avalable at newegg
You could up the HD 3870 to an 8800GT an additional 50 or 60 bucks. From what I've seen the 8800GT tends to grab you a higher FPS than the HD 3870 when it comes to gaming. As for the processor, if she is willing to go a bit over you could bump it up to a Core 2 Quad Q6600. As far as my opinion goes, upping the video card would be the better decision possibly. Keep in mind, I'm on a mind set that she would be willing to spend that whole $800 or possibly more. If that isn't the case then just ignore me completely.
Well thanx for the help everyone, I almost had a shopping list to get this build but she had to call and say she now wants 3 hd in it and wants to use the ancient voodoo3 card I gave her and now her budget went up to 900 bucks. I haven't even ordered anything yet and she wants to know when it'll be running.
You could always buy two kits of those G.Skill RAM for 4x1GB for only $80, along with maybe a slightly more powerful CPU?
wtf? shes raiding 3 hdd and then wants to use the voodoo???????????
if you are a friend then stop letting her make these choices, teach her why it makes no sense to do what shes asking.
for $800 you can get:
cpu - q6600 $280 http://www.newegg.com/product/product.asp?item=N82E16819115017
mobo - Gigabyte P35 DS3L $95 http://www.newegg.com/product/product.asp?item=N82E16813128059
ram - A-Data 2x1gb ddr2 800 $48 http://www.newegg.com/product/product.asp?item=N82E16820211066
hdd - 320gb wd caviar se 16mb cache $80 http://www.newegg.com/product/product.asp?item=N82E16822136074
vga - nvidia EVGA 8800gt $290 http://www.newegg.com/product/product.asp?item=N82E16814130303
Yeah, I know it don't make sense !!! :banghead:
Talked with her lastnight and just flat-out said it wont work then said I'm gonna only put the 250gb hdd that she has in.
I wonder what she's gonna change tonight :banghead: :banghead:
