Built in keyboard not working
Status
Not open for further replies.
DanielJH99
3 (0.00/day)
I recently purchased an ASUS ROG GL553VD Notebook Computer and a few weeks ago the keyboard stopped working. After a few restarts it worked again, but today the problem came back, and was not fixed by any amount of restarting. Several people on past posts said to reinstall they Keyboard driver, but there was no Keyboard section in the Device Manager. I am currently resetting the laptop to factory settings to see if that fixes the issue. Any other suggestions would be greatly appreciated.
1,487 (0.31/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
Did you buy it new? Or second hand? If new RMA it. If you bought it used then after exhausting all attempts to reinstall driver or factory reset, you may want to buy a new keyboard for it and install it.
DanielJH99
3 (0.00/day)
I bought it second hand so I’ll most likely have to get a new keyboard. After restarting, it brought me to an American Megatrends screen asking me to push some keys to either continue or reject changes to the Trusted Platform Module, but I still can’t click anything, so I’m kind of stuck now.
Edit: The screen went away and startup continued as normal.
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
If the keyboard is still unresponsive after you get back in windows then you may want to check the keyboard ribbon cable to be sure its connected correctly before buying a new keyboard. (they are very finicky and if the original owner opened up then I bet its a poor installation than a bad keyboard. Common issue from newbies with these style Asus because you have to remove the keyboard ribbon cable to upgrade anything in them) https://www.asus.com/us/Laptops/ROG-GL553VD/
EDIT My bad actually these ones access from the bottom but check the cable anyway
DanielJH99
3 (0.00/day)
After setting up my account and stuff I went back to the Device Manager and there’s an Unknown Device listed that wasn’t there before. I’m assuming that it’s the keyboard, but I’m not entirely sure what to do with it. This device, as well as “USB xHCI Compliant Host Controller” have exclamation points over them.
I’ll check the ribbon cable if I can find the tools to open up the laptop.
6,270 (0.89/day)
New York
reinstall the mobo drivers starting with chipset first then reboot and do the rest. If still an issue check the ribbon cable.
https://www.asus.com/us/Laptops/ROG-GL553VD/HelpDesk_Download/
Welcome to TPU!! :lovetpu:
13,952 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I would attach a USB keyboard to it and see if that works.
7,704 (1.15/day)
System Name Back to Blue
Processor i9 14900k
Motherboard Asrock Z790 Nova
Cooling Corsair H150i Elite
Memory 64GB Corsair Dominator DDR5-6400 @ 6600
Video Card(s) EVGA RTX 3090 Ultra FTW3
Storage 4TB WD 850x NVME, 4TB WD Black, 10TB Seagate Barracuda Pro
Display(s) 1x Samsung Odyssey G7 Neo and 1x Dell u2518d
Case Lian Li o11 DXL w/custom vented front panel
Audio Device(s) Focusrite Saffire PRO 14 -> DBX DriveRack PA+ -> Mackie MR8 and MR10 / Senn PX38X -> SB AE-5 Plus
Power Supply Corsair RM1000i
Mouse Logitech G502x
Keyboard Corsair K95 Platinum
Software Windows 11 x64 Pro
Benchmark Scores 31k multicore Cinebench - CPU limited 125w
Certainly try this, also does it work flawlessly in the bios or a live disc? If so you have one odd OS issue, if not I'd suspect a cable issue, while the keyboard itself could be failing a specific key would be more common to work intermittently than the whole keyboard.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Some prabably spilt something on it. Your going to have to replace the board. Use a USB untill then
44,274 (6.80/day)
Im with jetster, either the ribbon cable was damaged or the keyboard controller went out totally
arogs88
4 (0.00/day)
2019.
ASUS ROG GL502VM.
I have the same problem , keyboard is unresponsive , backlight , power button and touchpad works fine.
I bought a gl502vm on ebay, at the very first start it asked me if i wanted to delete the TPM Trusted Platform Module pressing F12 if i remember well.
Then while setting up windows 10 the keyboard stopped working, after finishing the set up with the help of the on screen keyboard, i tried to reinstall the drivers, atk package etc.. nothing
The next days keyboard worked by itself at the start, it was all good for the whole day, i did a fresh windows 10 install, updated all the drivers found on asus website, played video games, everything worked perfect
Today, here we go again, keyboard doesn't work, none of the button work, no F keys, no ESC, no Window key nothing.
I had set the backlight ON the previous day, so the backlight works, the power button works fine.
I am suspecting a loose connection, i will check that
I will update my findings
edit : can not access the bios at start because F2 doesnt work .
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
Please start your own thread, not just because this thread is old but the OP of the thread has not visited in some months.
Status
