ASRockIQ
- Dec 9, 2008
- 948 (0.16/day)
- Daphne, AL
System Name | Watermark |
Processor | Athlon II X4 620 @3.3GHZ V1.4250 |
Motherboard | ASRock A780GXE/128 |
Cooling | XIGMATEK HDT-S963 | 4 Blue LED 120mm Fans 1 Regular 120mm |
Memory | G.SKILL 4GB (2 x 2GB) @850MHZ |
Video Card(s) | Sapphire 6850 1GB (@stock) |
Storage | 320GB OS | 160GB Storage |
Display(s) | ASUS VH236H 23" 1920x1080 |
Case | COOLER MASTER Centurion 590 (With Side Panel Window) |
Audio Device(s) | Onboard |
Power Supply | Rosewill 600W 12V Rail@44 |
Software | Windows 7 Ultimate 64-Bit Edition |
Hello there, we recently acquired Mediacom Digital Cable which of course came also included their Internet Deal 12MB connection. with that, i am trying to refresh my memory here. i have a D-Link 524 Wireless Router but from what i remember it's important to only have one device set to DHCP and the other set as Wireless Access Point/Switch Port. currently, i think they are both set as DHCP. i never messed with the Router so it's set as Default right now and man... i cannot watch a youtube Video or any other video around the net. takes forever to buffer. anywho, i will try a direct link to the computer that's upstairs and see if the Router is the issue which i'm sure it is cause two devices set as DHCP doesn't mix.
So steps to do:
A: Try Direct Link and see if the speed issue goes away
B: If issue is related to Router then set Router to Access point/Switch Port
So steps to do:
