can ai suite invoke user defined settings for vcore?
192 (0.03/day)
Processor i7-3770K @ 45x100
Motherboard P8Z77-V Pro
Cooling Noctua NH-D14
Memory G.SKILL Ripjaws X Series (2 x 8GB) DDR3 1600/F3-1600C9D-16GXM
Video Card(s) Onboard HD4000
Storage Vertex 4 128 GB + other HDDs
Case P183
Power Supply Seasonic SS-560KM
Is there a way within one of the apps containing in Asus AI Suite to allow one to manually set both the FSB and vcore? I've played around with AINOS and AIBooster but can't find a manual vcore setting. For example, I'd like to specify the following two settings:
9x266 @ 1.1275V
9x333 @ 1.2625V
Thanks for any info. Why you might ask? I want the ability to switch between 2.4 and 3.0 GHz without a reboot and I want to vary the vcore as well.
Thanks in advance for any info.
What Bios version you running, I'm sure you know that AIBoost will not work with C-n-Q enabled. Lookin for extended options, but it appears that you wil have to get the Bios Modded or AI Ha...Adjusted.
:toast:
BIOS 1101; I don't think this board has C-n-Q... isn't that an AMD thing?
Yeah, it is. I think he meant to say SpeedStep, which is Intel's equivalent.
I don't see a section in the AIBooster app at all for vcore with or without speedstep enabled. Can anyone w/ a C2D/C2Q confirm this as well?
