Can I replace the power supply from my PC with another one?
65 (0.08/day)
Hi,I want to replace the power supply from my PC with another supply . Does it need to be at the same power consumation and model?
My PC is HP PRO TOWER 6005!
Also,what cables should I use for the new power supply?
Can I use the cables from the motherboard if I don't have cables to plug them in?
Can someone give me a list of what cables I should buy?
18,584 (2.64/day)
System Name AlderLake
I don't think you can just drop in another PSU unfortunately, the connectors are probably HP proprietary....
4,933 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
like P4-630 stated that PSU I believe only comes with 3-4 cables for a specific HP mobo
if it's dead your best bet is simply a replacement for unit make for your PC
something along the lines of this
65 (0.08/day)
Why not? Does that mean I have to buy the cables too?
If so what cables do I need for the Power Supply?
4,933 (0.97/day)
you would need an ATX 24 pin to four pin converter for your mobo's power. The main issue is most of the cables are from 3rd party suppliers and vary in quality meaning you can fry your mobo and that will cost you more than a new PSU.
What exactly is the issue you are trying to solve? Do you have a dead PSU? Or do you need more power in your current system?
65 (0.08/day)
you would need an ATX 24 pin to six pin converter for your mobo's power. The main issue is most of the cables are from 3rd party suppliers and vary in quality meaning you can fry your mobo and that will cost you more than a new PSU.
I don't have a dead PSU,I just want to replace it with another one so that I can get more power.
Also,I need the PSU to have a connection to the graphics card in case the graphics card does not intall on my PC!
It seems that the power supply is locked in the PC. Do I have to unscrew every screw or what do I have to do to replace the power supply?
4,933 (0.97/day)
Your best bet would be the HP forum as I'm sure other people have had a similar issue. Possibly someone may have used their ATX 20+4 connector as just a 4 connector with success or maybe it do it not work at all but that would be your best bet.
Your images are a bit fuzzy but yes you unscrew typically four screws (maybe less on some mass produced systems)
314 (0.16/day)
Elsewhere, USA
Processor AMD R7 9800X3D
Motherboard Gigabyte B850M Gamering X Wifi
Cooling Thermalright Phantom Spirit (7 pipe)
Memory Flare X 16GB x2 6000 MT/s 28-36-36-96
Video Card(s) Sapphire RX 9070 XT Pulse (-100mV, -15% PL)
Storage WD SN850X 2 TB
Display(s) Acer XV340CK x2
Case Lian Li A3 black, mesh, woodgrain
Power Supply Corsair RM750e (2025)
Software ZorinOS Pro
What graphics card are you trying to install in a BTX system?
5,471 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
Looks like a 12V only supply, so the 12V standby would be a problem on a normal supply.
18,584 (2.64/day)
Sorry, I don't understand why some people just don't upload photos to the post itself...
If someone visits this thread in 6 months from now I bet all you see is "X" from imgur......:shadedshu:
5,471 (3.65/day)
Colorado, U.S.A.
Don't need a new power supply for that video card
4,933 (0.97/day)
ATI RADEON HD 8490
So that means I can replace the power supply or not?
what shrek said, the card only pull 35w max and gets all it's power from the pci-e x16 slot. no additional power is needed so you are good to go as is
5,471 (3.65/day)
Colorado, U.S.A.
I have a similar HP and run a GT 1030 on it.
1,212 (0.59/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
Some Dells and HP machines will only work with a handful of gpu cards, even if your machine meets the spec sometimes will not work with one brand or the other. Also there are power supply upgrade options you just need one that's compatible with your machine (which means HP branded for use with HP 6005 model), the normal ones are usually 240watts but you can upgrade to a 320watt (unless you already have 320watt).
65 (0.08/day)
I want to change the power supply for more power consumation(300-500 watts). Is that possible?
4,933 (0.97/day)
it's hard to tell from your pics because they are fuzzy but it seems you already have the 320w unit
also, what are the rest of your specs? I'm guessing even with the HD8490 you will barely break 125w in total peak power. I think you are trying to solve a problem you don't have
1,428 (0.79/day)
It's not just about form factor, HP does this thing (at least it did with their P4 computers) where voltages were just a wee bit higher than ATX specs, over 13 volts instead of 12.6 max and such, and some proprietary connections. Just keep your current PSU, they are at least better quality than many low wattage PSU in the wild.
310 (0.06/day)
System Name Uzuki Toune
Processor AMD RYZEN 7 7700X (ASUS PBO 90C Mode)
Motherboard Asus ROG Strix X670E-E Gaming WIFI
Cooling Thermalright Frostspirit 140 White V3 ARGB
Memory 32GB DDR6000 CL36 Kingston (EXPO)(16GBx2)
Video Card(s) Zotac GTX 1050TI
Storage 2TB Kingston KC3000 + 1TB Crucial P2 + 480GB Samsung Evo 850 + 480GB Kingston A400
Display(s) Dell U2723QE + Philips 221V8 (Portrait)
Case NZXT H510
Audio Device(s) Auzen X-FI Forte + Onboard Realtek 4080 -> Creative Gigaworks T40II
Power Supply EVGA G+ 650W
Mouse Logitech MX Master 3 (Work) & G103 (Play)
Keyboard iRocks K71M
Note that I ALWAYS refer to official sources and READ them THOUROUGHLY before posting. In this case I looked up service and parts manuals on the HP website. Many people above me doesn't seem to do the same and seem to do alot of guessing. Just beware.
The HP PRO Tower 6005 only has one power supply variant, the 320w one. No need to worry there. There are no lower or higher wattage ones.
Among the GPUs that HP lets you add to the system, one of them is the ATI Radeon HD 4650. This gpu has a higher power consumption of 48w compared to your HD8490 which consumes 35w. If HP is confident their 320w PSU can handle their system with a 48w GPU, a 35w GPU would be even more so without issue. So no you don't need to upgrade your power supply.
5,269 (0.86/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
Premade machines from big name brands like that will make it so you cannot easily replace parts in them. It's one of many reason to build your own PC.
Look on ebay/amazon for the specific power supply that tower has and replace it with that.
4,933 (0.97/day)
@thewan Maybe YOU should READ the whole thread THOROUGHLY before posting
5,471 (3.65/day)
Colorado, U.S.A.
There used to be conversion cables out there as the 5V standby needs to become 12V standby, but I don't know if there are any for your HP; i.e. there was a small switcher circuit in the cable.
The HP supply has a fan in it controlled by the mother board, you will also lose this control.
In the end I just felt it wasn't worth the trouble and I just recapped the original supply so I knew it would last.
