Hello.
I'm trying to put my KHADAS Edge-V into "upgrade mode" because I want to install FreeBSD to the sd-card. Here is explained how to do it :
docs.khadas.com
The method that I want to try is the MRegister Mode (Maskrom Mode) : / because the other methods failed / ; this is how to do it :
Now my problem is that I can't use the tweezer because my hands are trembling because I have an health problem. But maybe I found an alternative tool that could short-circuit the two pads of M register. This is the tool that I'm talking about :
Do you think it / they will work ? Because my health problem,I'm more comfortable placing some magnets on top of those resistors thant using the tweezer.
but how can I use the magnets ? Should I place one magnet on top of each resistor or one only magnet on top of one resistor but touching both the resistors ?
Thanks.
Edge1 Boot into Upgrade Mode [Khadas Docs]
- Power-on Edge.
- Use a tweezer to short-circuit the two pads of M register, then without releasing.
- Short press the Reset key and release it to boot into Upgrade Mode (Maskrom Mode).
Vinabo 60Pezzi Magneti, al Neodimio Rotondi Piccoli 6 mm x 3 mm, Mini Calamite per Frigo, Lavagne, Artigianato, Mappe, Decorazioni - D'argento : Amazon.it: Commercio, Industria e Scienza
www.amazon.it
Thanks.
