lukueloges
- Mar 31, 2025
- 2 (0.05/day)
Hi can i yust plug 4pin cpu coler to 5 pin ? its a dell optiplex and i wnat to replace that coler with someting else for i7-3770 for better temps
System Name | YACS amd |
Processor | 5800x, |
Motherboard | gigabyte x570 aorus gaming elite. |
Cooling | bykski GPU, and CPU, syscooling p93x pump |
Memory | corsair vengeance pro rgb, 3600 ddr4 stock timings. |
Video Card(s) | xfx merc 310 7900xtx |
Storage | kingston kc3000 2TB, amongst others. Fanxiang s770 2TB |
Display(s) | benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H, |
Case | lian li LANCOOL III |
Audio Device(s) | obs, |
Power Supply | FSP Hydro Ti pro 1000w |
Mouse | logitech g703 |
Keyboard | durogod keyboard. (cherry brown switches) |
Software | win 11, win10pro. |
System Name | Z77 Rev. 1 |
Processor | Intel Core i7 3770K |
Motherboard | ASRock Z77 Extreme4 |
Cooling | Water Cooling |
Memory | 2x G.Skill F3-2400C10D-16GTX |
Video Card(s) | EVGA GTX 1080 |
Storage | Samsung 850 Pro |
Display(s) | Samsung 28" UE590 UHD |
Case | Silverstone TJ07 |
Audio Device(s) | Onboard |
Power Supply | Seasonic PRIME 600W Titanium |
Mouse | EVGA TORQ X10 |
Keyboard | Leopold Tenkeyless |
Software | Windows 10 Pro 64-bit |
Benchmark Scores | 3DMark Time Spy: 7695 |
System Name | Metalia |
Processor | AMD Ryzen 7 5800X3D |
Motherboard | Asus TuF Gaming X570-PLUS |
Cooling | ID Cooling 280mm AIO w/ Arctic P14s |
Memory | 2x32GB DDR4-3600 |
Video Card(s) | Sapphire Pulse RX 9070 XT |
Storage | Optane P5801X 400GB, Samsung 990Pro 2TB |
Display(s) | LG 32GS95UV 32" OLED 240/480hz 4K/1080P Dual Mode |
Case | Geometric Future M8 Dharma |
Audio Device(s) | Xonar Essence STX |
Power Supply | Seasonic Focus GX-1000 Gold |
Mouse | Attack Shark R3 Magnesium - White |
Keyboard | Keychron K8 Pro - White - Tactile Brown Switch |
Software | Windows 10 IoT Enterprise LTSC 2021 |
System Name | Obliterator |
Processor | Ryzen 7 7700x PBO |
Motherboard | ASRock x670e Steel Legend |
Cooling | Noctua NH-D15 G2 LBC |
Memory | G.skill Trident Z5 Neo 6000@CL30 |
Video Card(s) | ASRock rx7900 GRE Steel Legend |
Storage | 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd |
Display(s) | LG 27GN750-B |
Case | Fractal Torrent |
Audio Device(s) | Klipsch promedia heritage 2.1 |
Power Supply | FSP Hydro TI 1000w |
Mouse | SteelSeries Prime+ |
Keyboard | Lenovo SK-8825 (L) |
Software | Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM |
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Probably be easier for op to get an adapter+1 for re-pining fan connectors with a sewing needle. It's my tool of choice.
I have a molex extractor tool kit somewhere......haven't used it in years, but they do make extractor tools if you so desire.
https://modmymods.com/phobya-molex-extractor-kit-sleeving-tool-32134.html
If you are gonna buy something, the converter cable that LabRat linked is your easiest option.
System Name | Laptop ASUS TUF F15 | Desktop 1 | Desktop 2 |
Processor | Intel Core i7-11800H | Intel Core i5-14600K@135W | Intel Core i3-10100 |
Motherboard | ASUS FX506HC | Gigabyte B660M DS3H DDR4 | MSI MAG B560M Bazooka |
Cooling | Laptop built-in cooling lol | Thermalright Assassin Spirit w/ BeQuiet Shadow Wings fan| Stock Copper |
Memory | 24 GB @ 3200 | 32 GB @ 3733 | 16 GB @ 3200 |
Video Card(s) | Nvidia RTX 3050 Mobile 4GB | Nvidia GTX 1650 | Nvidia GTX 960 2 GB |
Storage | Adata XPG SX8200 Pro 512 GB | Samsung M2 SSD 256 GB & 1 TB 2.5" HDD @ 7200| SSD 250 GB & SSD 240 GB |
Display(s) | Laptop built-in 144 Hz FHD screen | Dell 27" WQHD @ 75 Hz & 49" TV FHD | Samsung 32" TV FHD |
Case | It's a laptop, it doesn't need case lmfao | Deepcool Mattrexx 55 MESH | Aerocool Cylon PRO |
Audio Device(s) | laptop built in audio | Logitech 2.1 speakers | Logitech stereo speakers |
Power Supply | ASUS 180W PSU | SeaSonic Focus GX-550 | SeaSonic M12II EVO 520W |
Mouse | Logitech G604 | Corsair Harpoon wired mouse| Logitech G305 |
Keyboard | Laptop built-in keyboard |Razer Blackwidow | Steelseries APEX 7 TKL |
VR HMD | Quest 2 sold out and don't need VR anymore lol |
Software | Windows 10 Enterprise 20H2 | Windows 10 Enterprise 20H2 & Ubuntu Mate 24.04.2| Windows 11 24H2 LTSC |
Benchmark Scores | good enough |
the fun part is - Dell uses 5-pin for case fans, but not for CPU fans. Have seen like ~10 random Dell machines diff era. Case fans proprietary, CPU cooling 4-pin common standard fans.U can always try if adapter will fit. These older dell office computers come with different pin layouts than in common atx diy motherboards. Besides...5 pins sounds better than 4 isn't..more pins...more power...better coling!
https://dl.dell.com/manuals/all-pro...er's manual4_en-us.pdf?utm_source=chatgpt.comi assume you talk about mainboards. check the mainboard manual first. please link that manual here so we all can look into it first
great stuff, if it was me i would chop the wires and solder them, or depending on how impatient I am, just twist the wires together add electrical tape and away you go… (or if a I am feeling great shrink wrap the wire)Funny that you're in this situation, I've typically done the opposite: -re-using 120x38mm blowers, etc, salvaged out of old Dells.
You have 2 options:
1. Purchase the adapter meant for this application:
Amazon: CRJ 5-Pin PWM PC Fan Adapter Cable for Dell Motherboards - 6-inch (15cm), Black Sleeved - Connect Standard 4-Pin Computer Fans to Dell Latching 5-Pin Fan Headers
Moddiy:![]()
5 Pin to 4 Pin PWM Fan Converter Sleeved Cable 20cm for Dell
Buy 5 Pin to 4 Pin PWM Fan Converter Sleeved Cable 20cm for Dell for $9.99 with Free Shipping Worldwide (In Stock)www.moddiy.com
2.Re-pin the 4-pin fan to match the Dell arrangement (rendering that fan incompatible w/ other builds), and ensure you properly align the pins upon installation.
Fan plugs are easier to re-pin w/o the proper tools, than other common plugs/receptacles. I've used sewing needles, paperclips, or the edge of a small blade to unseat the pins.
Kludge job or not,great stuff, if it was me i would chop the wires and solder them, or depending on how impatient I am, just twist the wires together add electrical tape and away you go… (or if a I am feeling great shrink wrap the wire)
https://dl.dell.com/manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-7010_owner's manual4_en-us.pdf?utm_source=chatgpt.com
this is only manual from dell for that mobo GY6Y8
