OrbitzXT
- Mar 22, 2007
- 1,969 (0.30/day)
- New York City
System Name | AX-01 |
Processor | Intel Core i5-2500K @3.7 GHz |
Motherboard | ASRock Z68 Extreme3 Gen3 |
Cooling | Zalman 9700 |
Memory | Kingston HyperX T1 Series 8GB DDR3 1600 MHZ |
Video Card(s) | GTX 590 |
Storage | Intel X25-M |
Display(s) | 42" Samsung LED HDTV |
Case | Antec Twelve Hundred |
Audio Device(s) | HT | OMEGA STRIKER 7.1 |
Power Supply | Kingwin 1000W |
Software | Windows 7 64-Bit |
I had a computer that had a 9400GT in it. I took out the GPU and put it into another computer because I needed the DVI input from the video card. The computer I took the card from I cannot get to display an image now. On it's motherboard, it has 2 DVI ports. A DVI-D and DVI-I. I've tried both with no success. It was some basic custom built PC for the office here with a simple Intel motherboard that I can't even find a model number for. It just says "Intel Desktop Board".
I've tried taking out the battery, I don't see a typical set of Clear CMOS pins. There are no VGA ports on the motherboard so I can't try a different monitor. Any thoughts on what I can do to get it working?
