Cant Flash 9550 Help!!!
Zapp
4 (0.00/day)
I tried to flash my Palit Xpert Vision RADEON 9550 with the same bios only with core/mem modified.I used flashrom 2.40. Didnt worked (tried even with a 9600PRO bios). flashrom -f -p 0 newbios.bin - ERROR bla bla bla - data not erased.
NEED URGENT HELP !!!
DEVIDE ID 4153
VENDOR ID 1002
SUBVENDOR ID 1FD3 (XpertVision)
Mem 128MB, 128 BIT Hinyx 307A - 3.6
Calm down next time and try to make a decent thread.............
hey Zapp.... same problem here to... :(
HEY Mr. Slayerstaps
If i hadnt a problem i would not posted this thread. RIGHT ?
And 4 me the fact that i couldnt flash my card is a real problem. Is a "decent thread".
K?
And again...if u r so damn smart come to me and flash my card urself. I dont wanna argue but i really need some help with that.
If u cant give me a real solution 2 my problem pls dont bother reply with that kind of message.
thx a lot
Calm down dude.. never be rude to the moderator.. :D
Here's some solution you might be interested..
1. My guess is that the board manufacturer might have use some form of BIOS lock to prevent users from flashing the BIOS..
2. Try to use the BIOS flash utility provided by provided by your board manufacturer..
You are not the one having this problem.. most Gigabyte 9550 users seems to have the same problem as you too.. here's an example.. http://forum.techpowerup.com/showthread.php?t=1430
hmmm. , my card gets the same.... odd indeed, thought it might be only the Gigabyte cards... odd that there are articles on this, but hence you cannot do it... :confused:
you might want to try the Omega Drivers, as they can unlock your card so you can overclock if that is what you are looking to do. I got my 9550 (overclocked) to a 3480 3D2K3 score... but i also ordered a Zalman Heatpipe for it to help cool it so i can overclock and leave it that way... right now i am running
300 core/ 225 mem (stock HS) once i get my heatpipe installed i will experiment with the overclocking some more...
good luck ( I guess just don't put "help" in your topic title ) there is a sticky on that... :o
((ati.bob .... I see you have a Saphire 9550 ...did you run flashrom to flash the bios, and what kind of mem do you have in your card ?))
Like ati.bob says don be rude dude it's my job to keep the place clean around here.. And if i start gettin reactions like this to my work i get pissed....and nothing good happens when i get pissed...
Yes.. I'm using FlashROM 2.40, my board comes with Samsung 5.0ns RAM chips... :D
