Morgoth
Fueled by Sapphire
- Aug 4, 2007
- 4,254 (0.65/day)
- Netherlands
System Name | Wopr "War Operation Plan Response" |
Processor | 5900x ryzen 9 12 cores 24 threads |
Motherboard | aorus x570 pro |
Cooling | air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick |
Memory | kingston 32gb ddr4 3200mhz ecc 2x16gb |
Video Card(s) | sapphire RX 6950 xt Nitro+ 16gb |
Storage | 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI |
Display(s) | AOC display 1080p |
Case | SilverStone SST-CS380 V2 |
Audio Device(s) | Onboard |
Power Supply | Corsair 850MX watt |
Mouse | corsair gaming mouse |
Keyboard | Microsoft brand |
Software | Windows 10 pro 64bit, Luxion Keyshot 7, fusion 360, steam |
Benchmark Scores | timespy 19 104 |
hi got 2 3tb toshiba pc p300 3tb had disk
problem is i cant get them back to work properly..
1 only sees as 2tb in windows
other one he sees it as 3tb drive (2700gb aprox)
i have them both connected to the sas controler sees them both as 2tb hard disk
i cant format the one it says to be 3tb under windows
but i cant make the other one bigger.. is my sas controller faulty?
they both used to be a raid 1 but some how that all got fucked up.. now im tryng to fix it
