cant load sound driver from Asus Striker Extreme
cgyacht
1 (0.00/day)
fort lauderdale, florida
I have an Asus Striker extreme mobo, c2d 2.13ghz, bfg 8800gts, 2megs of corsair ddr800, seagate barricuda 320 gig at 7200. I installed all on a new case and everything runs perfect except the sound. The Soundmax adi1988 card that comes with the mobo does not load. the driver install says I need an HD audio bus driver and that it is not found. What is this particular driver and will this prevent me from installing a different card in the future. Can I get one? I tried changing things in the BIOS and running the driver from the Asus website but to no avail.
Thanks in advance for any suggestions.
CG
CG
I was going to buy the striker extreme too, but i heard that there was a bug with the audio card, and that there was no fix for it...maybe try google it and see if anyone has created a fix for the problem but other than that i think the best option is to disable the onboard and buy a new sound card....perhaps its the only option
