Can't measure GPU temps
lylewaggoner
7 (0.00/day)
I have an ATI4850 and have been trying to find a simple tool that adds my GPU temp to the system tray. Apparently RealTemp can do this, but the GPU "show icon" checkbox in v3.40's settings is greyed out. GPU-z measures my GPU temperature fine (it just doesn't provide a temp reading in the system tray), so in theory I would have thought RealTemp wouldn't have any problems.
Is there a reason why this would be happening? Any help would be appreciated.
836 (0.12/day)
Romania
System Name Rocket
Processor Ryzen 3600X
Motherboard ASRock B450 PRO4
Memory HyperX Predator Black 16GB DDR4 3200MHz CL16
Video Card(s) MSI GeForce GTX 1060 GAMING X 6GB
Storage ADATA SX8200 PRO 512GB + Intel 535 Series 120GB + WD 6400AAKS
Display(s) Benq EW2420
Case Antec P182
Power Supply Antec Signature 650
Software Win 10
Try latest RealTemp beta.
Or you can try RivaTuner or his cousin MSI Afterburner.
lylewaggoner
7 (0.00/day)
The Beta kept crashing on launch, but setting it to Vista SP2 compatibility mode (I'm running Windows 7) seemed to fix it. Don't know what happened between the Beta and v3.40 to cause the crashes, as previously the program ran fine... In any case, the GPU option certainly works in this version, thank you!
If I could make one minor suggestion on this option, it'd be cool if the text colors for each option (GPU, Core0, Core1 etc) in the system tray could be customizable, other than that, it's fantastic.
836 (0.12/day)
Romania
System Name Rocket
Case Antec P182
Software Win 10
Aaa, Settings and click on GPU/Core0/Core1 and pick a color. :)
lylewaggoner
7 (0.00/day)
LOL, I thought I gave it a good check before posting that.
Thank you again, now I'm completely sorted. :)
lylewaggoner
7 (0.00/day)
Well, maybe not completely - adjusting the color for the system tray item doesn't seem to hold between quitting and relaunching (or restarting Windows, naturally)... Just a quick something the developer could look into maybe, probably easily fixed.
Thanks for a great product.
836 (0.12/day)
Romania
System Name Rocket
Case Antec P182
Software Win 10
AFAIK Apply button is only to see if you like what you change but settings are not remembered upon restart and OK button is for remembering settings.
TBH I forgot about RealTemp windows because I use only RealTemp plugin for RivaTuner. :)
lylewaggoner
7 (0.00/day)
I think I'd only been using OK anyway, but I just tested again - no difference in behaviour between that and the Apply button. Once you quit and relaunch, the text colors in the system tray revert to defaults. Not a dealbreaker by any stretch, but it'd be cool if the settings could persist. :)
836 (0.12/day)
Romania
System Name Rocket
Case Antec P182
Software Win 10
Man sorry, my colors works fine here, beta launches fine, in fact everything is fine on Seven x64. :)
