cant open zip files without saving first
georgesperis
1 (0.00/day)
When i get an attachment via email like a zip file i cant just open the file from the email i have to save and then open, i have tried the reg fix with the level security but still i cant open files, its a real pain
Ebo
778 (0.18/day)
Nykoebing Mors, Denmark
System Name the little fart
Processor AMD Ryzen 2600X
Motherboard MSI x470 gaming plus
Cooling Noctua NH-C14S
Memory 16 GB G.Skill Ripjaw 2400Mhz DDR 4
Video Card(s) Sapphire RX Vega 56 Pulse
Storage 1 Crucial MX100 512GB SSD,1 Crucial MX500 2TB SSD, 1 1,5TB WD Black Caviar, 1 4TB WD RED HD
Display(s) IIyama XUB2792QSU IPS 2560x1440
Case White Lian-Li PC-011 Dynamic
Audio Device(s) Asus Xonar SE pci-e card
Power Supply Thermaltake DPS G 1050 watt Digital PSU
Mouse Steelseries Sensei
Keyboard Corsair K70
Software windows 10 64 pro bit
mabye try winrar to open it ?.
luukbokhove
1 (0.00/day)
Please do the following to attempt to repair a Zip file:
Click Start, click All Programs, and click Accessories
Right click Command Prompt and choose Run as administrator
Change directories to the folder where the corrupted Zip file is located
Type: "C:\Program Files\WinZip\wzzip" -yf zipfile.zip
If the corrupted Zip file is split or spanned, use the following command instead:
"C:\Program Files\WinZip\wzzip" -yfs zipfile.zip
WZZIP will create a new Zip file with a FIXED suffix in the file name. The original Zip file will not be modified. Only the data in the original Zip file is used.
The FIXED Zip file is structurally sound but the data may still be corrupt. WZZIP does not fix the zipped data itself. If the zipped data has a CRC error or the zipped data is corrupt, then the resulting fixed Zip file will still be corrupt.
Useful resources, which might become solutions have more different information than guide above...
http://itknowledgeexchange.techtarg...p-files-after-zip-archive-corrupt-or-damaged/
