Carrizo vs Bristol detection bug
20 (0.00/day)
Hello,
we stumbled about a problem in our db over hwbot and kindly to ask to change the showed code name in GPU-Z from Bristol / Carizzo back to Wani.
This is (I think) needed because A6-9500 / A6-9550 / A6-9500E have an IGP with revision E6 but the late Carizzo A6-7480 has also E6. This results into the problem, that GPU-Z shows for the Carizzo CPU a Bristol GPU. Example.
On the other hand, A8-9600 currently is showing Carrizo GPU despite the fact it is Bristol CPU. This is again because rev E2 is also used for A8-7680. Example.
Name
Core
Socket
Shaders
Official/Spec Name
Hwbot Category
Rev
Bristol Ridge​
AM4​
384​
Radeon™ R5 Graphics​
E6​
Bristol Ridge​
AM4​
384​
E6​
Carrizo​
FM2+​
384​
E6​
Bristol Ridge​
AM4​
384​
Radeon™ R5 Series​
E6​
Bristol Ridge​
AM4​
384​
Radeon™ R5 Series​
E6​
Bristol Ridge​
AM4​
384​
Radeon™ R5 Series​
E6​
Bristol Ridge​
AM4​
384​
Radeon™ R7 Graphics​
Bristol Ridge​
AM4​
384​
Bristol Ridge​
AM4​
384​
Carrizo​
AM4​
384​
E2​
Carrizo​
AM4​
384​
Carrizo​
FM2+​
384​
E2​
Bristol Ridge​
AM4​
384​
Radeon™ R7 Series​
E2​
Bristol Ridge​
AM4​
384​
Radeon™ R7 Series​
Bristol Ridge​
AM4​
384​
Radeon™ R7 Series​
If the only difference between Bristol and Carrizo is DDR4 vs DDR3 and you made because of that a separation, we have a the next problem with the following CPUs which runs on early AM4 boards with DDR4.
Name
Core
Socket
Shaders
Official/Spec Name
Hwbot Category
Carrizo​
AM4​
256​
Carrizo​
AM4​
256​
Carrizo​
AM4​
384​
Carrizo​
AM4​
384​
Carrizo​
AM4​
512​
Carrizo​
AM4​
512​
Therefore I would suggest to change to codename back to Wani for both, as it is in TPU GPU DB too.
Thanks for the detailed report. On holiday this week, product launches next week, will try to work on this asap, remind me if i forget
Thanks for the quick reply.
Just for planing as I want to reconfigure our categories: Do you change the code name or will you
