- Jan 5, 2006
- 18,584 (2.62/day)
System Name | AlderLake |
Processor | Intel i7 12700K P-Cores @ 5Ghz |
Motherboard | Gigabyte Z690 Aorus Master |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p |
Case | Be quiet! Silent Base 600 - Window |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W |
Mouse | Logitech MX Anywhere 2 Laser wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless |
Software | Windows 11 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
Since I have installed the latest (8.7) driver I have a problem with ati overdrive.
I have unlocked it, set the sliders to overclock (as usual what I do with each new catalyst driver), click apply, checked the box "Enable ATI Overdrive" but the clocks are not going up when running furmark or rthdribl (Real-Time High-Dynamic Range Image-Based Lighting).
Usually the core and mem clocks go up immediately.
Yesterday I already re-installed the 8.7 driver because of this, and yesterday after the re-install the clocks went up as I set them but today the clocks stay at stock speeds, no matter what I set in ati overdrive.
Rivatuner always works fine but with rivatuner the core clock is not going down when the gpu does not have to work, so thats why I prefer using ati overdrive.
This is the first time that I have problems with ati overdrive.
Anyone else problems with this?
Catalyst 8.7 ATI Overdrive works fine,
I have some games that I run windowed such as TmNationsForever, now with catalyst 8.7 the ati overdrive clock speeds only engage when running 3d at full screen.
