CCleaner 2.01.507
HellasVagabond
3,376 (0.50/day)
Athens , GREECE
System Name SECONDARY RIG / PRIMARY RIG / THIRD RIG
Processor i920@3.6GHz / i920@4GHz / AMD Phenom II 955
Motherboard Gigabyte EX58-UD4P / Gigabyte EX58-UD7 / ASRock 890GX3
Cooling CoolIT Domino ALC / Thermalright Silver Arrow / Thermalright VenomousX
Memory 12GB DDR3 @ 1800MHZ / 6GB DDR3 @ 2250MHZ / 4GB DDR3 @ 1600MHZ
Video Card(s) XFX ATI RADEON 5970 / GAINWARD NVIDIA GTX 580 / 2xGEFORCE GTX295
Storage 1550GB / 6TB SAS - SSD / 160GB SSD
Display(s) NEC 26WUXi2 / NEC 3090WQXi / SONY 55A2000 (1080P 55inch)
Case COOLER MASTER HAF 932 / COOLER MASTER ATCS 840 / ANTEC DARKFLEET DF85
Audio Device(s) Soundblaster X-Fi Xtreme Music / SoundBlaster X-Fi Fatal1ty Pro / Realtek Onboard
Power Supply CWT 1200W / Enermax Revolution 85+ 1250W / Ikonik Vulcan 1200W
Software Windows 7 x64 / Windows 7 x64 / Windows 7 x64
CCleaner is a freeware system optimization and privacy tool. It removes unused files from your system - allowing Windows to run faster and freeing up valuable hard disk space. It also cleans traces of your online activities such as your Internet history. But the best part is that it's fast (normally taking less than a second to run) and contains NO Spyware or Adware!
Cleans the following:- Internet Explorer: Temporary files, URL history, cookies, Autocomplete form history, index.dat.
- Firefox: Temporary files, URL history, cookies, download history.
- Opera: Temporary files, URL history, cookies.
- Windows: Recycle Bin, Recent Documents, Temporary files and Log files.
- Registry cleaner: Advanced features to remove unused and old entries, including File Extensions, ActiveX Controls, ClassIDs, ProgIDs, Uninstallers, Shared DLLs, Fonts, Help Files, Application Paths, Icons, Invalid Shortcuts and more... also comes with a comprehensive backup feature.
- Third-party applications: mRemoves temp files and recent file lists (MRUs) from many apps including Media Player, eMule, Kazaa, Google Toolbar, Netscape, MS Office, Nero, Adobe Acrobat, WinRAR, WinAce, WinZip and many more...
- 100% Spyware FREE: This software does NOT contain any Spyware, Adware or Viruses.
Features of CCleaner 2.0:
* Complete rebuild in C++
With the requirements for a portable version, 64-bit compatibility and Windows Vista increasing against the limitations of the old architecture. We decided to rebuild the entire CCleaner application in highly optimized C++.
* Faster analyzing and cleaning
Each scanning process was rewritten from scratch and fully optimized. The result being a noticeable speed increase in all areas.
* Portable
CCleaner can now run from a USB thumbdrive and be installed/run on a computer without a complicated setup process.
* Compact
The rewrite removed all external file dependencies, so the main EXE is now half the size of the original program and support files.
* Redesigned User Interface
The original CCleaner user interface was looking a little dated, so the GUI was redesigned with a modern look, but without sacrificing speed or usability. New icons were created for the interface and the main program icon was updated with a more modern style.
* Exclusions
It is now possible to specify files, folders and registry keys to ignore from the cleaning process.
* Loads of little tweaks
Too numerous to mention them all separately, we've tried to improve CCleaner in all areas.
Changes in CCleaner v2.01:
- Fixed bug where some IE Temporary files were not removed.
- Fixed bug with IE7 Recently Typed URLs cleaning.
- Fixed C++ exception on Desktop shortcut scanning.
- Installer now works on 64-bit OS Recycle Bins menus.
- Optimized IE Temp files cleaning speed.
- Improved index.dat cleaning on XP.
- Fixed Registry Cleaner as "Fix All" sometimes wouldn't work.
- Keyboard shortcuts now work correctly in Registry section.
- Files winsys.ini and winreg.ini are now embedded in the EXE.
- Fixed bug where Autoupdate check could cause an exception.
- Fixed minor bug in restoring screen position and size.
- Lots of internal improvements to reliability and speed.
Download and Enjoy people :)
