Cheapest NAS RAID5 solution
7,013 (1.41/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Hi all,
I would like to purchase a cheap enclosure for a NAS with RAID5 setup (4xHDD drives) for backup and storage purposes, however I was checking online and the prices are beyound retardness.
For example Amazon:
https://www.amazon.com/s/ref=sr_nr_...raid+5&ie=UTF8&qid=1531962920&rnid=2941120011
I mean I want to buy just the enclosure, not necessarly with the 4 drives included, and USB3.0 only it's also OK. I just need RAID for redundancy in case 1 of the drives fails...
Any good tips for some good cheap sollutions?
Thank you in advance.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Your talking about a drive enclosure and a RAID managed by the motherboard. It would have to be SATA as with USB there is no RAID option. (that I know of)
It's what a NAS cost. Its basically a PC. Maybe pick up a Used Synology. Or better yet build a FreeNAS or UnRAID using some old hardware
And reduntcy is not a back up. Redundancy just provides reliability. For years i just used drives and back the stuff up in case a drive fails. Eventually I have to much stuff for one motherboard and it was starting to get buggy so I bought a DS216 and ran RAID 0 still backing it up. Now I have a FreeNAS in RAID6 and its still being backed up
7,013 (1.41/day)
Yeah, I was thinking more as an external enclosure that has integrated RAID5 capabilities, just like those:
https://www.wdc.com/solutions/raid.html
But the prices seems to crazy for my taste....
12,340 (2.21/day)
Oregon
I did a review on Western Digital Cloud Home Duo. They are really new to the NAS market. They run a little cheaper but they don't have enough ram and minimal apps
If you can get a hold of a Intel Pentium or i3 and 8 Gb ram you can build one. 4 drives + USB thumb drive for the OS
I have some 3 Tb drives laying around I'll sell cheap. That's how I got started
A NAS takes the overhead off you system. I had all my drives were in my HTPC and it was stating to get a little buggy. Hanging and weird hesitations. After getting a NAS all that stopped
Even though a RAID 5 has one redundant drive its not the best solution. Really its obsolete with large drives. If a drives fails by the time it rebuild you could lose another drive. RAID 6, RAID 10 and RAID 50, 60 are better
UnRaid is a really unique set up. Its not a RAID as the name implies. But it does have redundancy and the ability to add drives of any size to a pool. Without rebuilding your pool. It's also one of the easiest to set up
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
https://www.newegg.com/Product/Product.aspx?Item=N82E16816322004
There you go.
This largely untrue and I wish people would stop saying it. Yes, RAID6 is better with large drives, but RAID5 is not obsolete, it works well. Rebuild times are a concern, but not really any worse than they were a decade ago. The drives haven't just gotten bigger, they've gotten faster. The controllers and hardware have gotten faster too. When I started with RAID I had 3 320GB hard drives, the rebuild time was almost 2 days. Now with 3x6TB hard drives, the rebuid time is about a day.
The real place you should be using RAID6 is with a large number of drives. That is where RAID5 is obsolete.
RAID10 and RAID50 both still rely on a single drive for redundancy, so no, they aren't any better than plain RAID5 other than for speed.
12,340 (2.21/day)
Oregon
7,013 (1.41/day)
Thank you all. That's the device I was looking for. Not sure if I can find it here though....
