Check Disk On every Boot
Johnytxtc
38 (0.01/day)
China, Beijing
Last week a monkey got in to my study and caused quite mess. I shot at it but missed but it was enough to scare it out of the window again. As it went out it run on my keyboard. I don't know what buttons got pressed but the computer restart. Now every time I turn PC on it wants to check my Z: Drive. Each time there is no problem but it will not stop this each time.
What can I do to stop this checking each time?
PVTCaboose1337
Graphical Hacker
9,501 (1.35/day)
Texas
System Name Whim
Processor Intel Core i5 2500k @ 4.4ghz
Motherboard Asus P8Z77-V LX
Memory 2 x 4GB G.Skill Ripjaws @ 1600mhz
Video Card(s) Gigabyte GTX 670 2gb
Storage Samsung 840 Pro 256gb, WD 2TB Black
Display(s) Shimian QH270 (1440p), Asus VE228 (1080p)
Case Cooler Master 430 Elite
Audio Device(s) Onboard > PA2V2 Amp > Senn 595's
Power Supply Corsair 750w
Software Windows 8.1 (Tweaked)
LOL, good story bro.
Does the computer boot?
Does the "z:" drive show up in my computer?
Do you actually use a z: drive?
Johnytxtc
38 (0.01/day)
China, Beijing
The z: drive is a 250gb WD that I use for storing MP3 pictures and videos. Yes the PC boots fine if I don't skip the check it's very quick and it reports no problem as far as i can see. named it Z: just for fun I dont have 25 other drives. I did change the drive letter back to E: but made no differance.
967 (0.13/day)
Danville IL
Processor I7 4770k
Motherboard ASUS z87 pro
Cooling Corsair a50
Memory 4x4 gig Gskil aries ddr3 1866
Video Card(s) Gigabyte r280x windforce
Storage intel 520 120 gig ssd
Display(s) 24 inch Asus IPS
Case Cool Master
Audio Device(s) realtek onboard
Power Supply hiper 880
Software win 7 ult
Scedule another scandisk on that drive and let it scan it 1 more time and see if it goes away after a sceduled scandisk.
Saakki
301 (0.05/day)
Finland
System Name JGG
Processor Q6600 @ 3,4ghz
Motherboard Rampage Formula
Cooling Xigmatek, Nexus
Memory 1100 mhz Pi
Video Card(s) 6950 + Accelero Xtreme Plus
Storage 1tb+1tb
Display(s) Acer 19" LCD 5ms + 17 " Hitachi
Case Fractal Design Define R2
Audio Device(s) X-FI
Power Supply XFX Core 650
Software Win 7 ultimate x64
Benchmark Scores Q6600 @ 3.5 ghz + and 6950 @ 6970 +
i had this same irritating problem lately..i just disabled auto chkcdisk and problem solved :)
taken from:
http://www.raymond.cc/blog/archives/2008/02/23/disable-or-stop-auto-chkdsk-during-windows-startup/
"There are some people suggested to edit the registry but the proper way to disable CHKDSK from starting up is using the /x switch on chkntfs command in command prompt.
( go to Run and type CMD and press enter ).
The /x switch will exclude a drive from the default boot-time check. If you have drive C: as your hard drive, then the command to disable chkdsk from scanning C: drive would be:
chkntfs /x c:
If you have 2 drive, C and D, you can disable chkdsk with the command below :
chkntfs /x c: d:
worked for me
Johnytxtc
38 (0.01/day)
China, Beijing
Thankyou Saakki that worked great, It loads right into windows each time now :toast:
Saakki
301 (0.05/day)
Finland
System Name JGG
Memory 1100 mhz Pi
Storage 1tb+1tb
no problem mate:toast:
PVTCaboose1337
Graphical Hacker
9,501 (1.35/day)
Texas
System Name Whim
OMG he stole my avatar...:confused:
Saakki
301 (0.05/day)
Finland
System Name JGG
Memory 1100 mhz Pi
Storage 1tb+1tb
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
Polarman
1,626 (0.26/day)
Rimouski
System Name Polar's Dragon
Processor AMD Phenom II 975BE
Motherboard MSI 890FXA-GD65 (Bios 18.7)
Cooling Zalman CNPS 9700 Led
Memory Gskill 8GB DDR3-1333 (8,8,8,21)
Video Card(s) MSI HD6870 Hawk
Storage WD Raptor 250 - WD RE4 500GB
Display(s) Samsung T240 (1920 X1200)
Case Silverstone Raven 2
Power Supply PC Power&Cooling Silencer 750 (Red)
Software Windows 7 Home Premium 64Bit + SP1
1,365 (0.22/day)
Alden, NY
System Name Turbo_Fighter/Pitbull
Processor AMD FX-9590/Intel i7 6700K 4.7GHZ @ 1.41 volts
Motherboard Gigabyte 990FXA-UD3 Rev 4.0/Gigabyte GA-Z170N-Gaming 5
Cooling Corsair H105/Corsair H100iv2
Memory 32 GB G.Skill Ares/32 GB G.Skill Trident-Z
Video Card(s) XFX Radeon R9 Fury X/Sapphire R9 Nano
Storage Mix of HDDs SSDs Externals and a 256GB Samsung M.2 in the pitbull
Display(s) 24" Nixeus 144hz freesync/24'' Benq XL2420TE/21.5'' Asus VH226/Panasonic 42" Plasma
Case White Phantom NZXT/Fractal Define Nano S
Audio Device(s) MayFlower O2 ODAC/HT Omega Claro+/Turtlebeach Earforce DSS
Power Supply Corsair AX1200i/Thermaltake Smart 650Watt(EVGA GS 650 Watt took a shit on me)
Keyboard Corsair K70
Benchmark Scores They can run Crysis.
+500 internet cookies to you thread starter.
Saakki
301 (0.05/day)
Finland
System Name JGG
Memory 1100 mhz Pi
Storage 1tb+1tb
did he copy kiriakost avatar now :roll: :roll:
