- Nov 8, 2008
- 779 (0.13/day)
- Sydney, Australia
System Name | Gearbox || Server |
Processor | i5 3570K @ 4.0Ghz || E8400 @ Stock 3Ghz |
Motherboard | Gigabyte Z68XP-UD3 || Gigabyte EP41-UD3L |
Cooling | Stock || Stock |
Memory | 8GB G.Skill RipjawX DDR3 @ 1600mhz || 4GB Kingston Value DDR2 800Mhz |
Video Card(s) | ASUS R9 270X Direct CU II TOP @ 1120/1500 || N/A |
Storage | Samsung 840 EVO 250GB || 1TB WD Green, 2TB WD Green, 3TB WD Red |
Display(s) | HP x23 LED 23" Full HD Panel |
Case | Corsair 200R || Open-Air |
Audio Device(s) | Audioengine D1 + Logitech Z623/Audio Technica ATH-M50 || N/A |
Power Supply | Antec EarthWatts Platinum 650 W || Antec Neo Eco 450 W |
Software | Windows 8.1 Update 3 Pro 64 || Ubuntu Server 14.04 64 |
Hey guys, I solved my problem earlier abour getting folder names into the list box using this code:
But now I need help dumping only the checked items in the checked listbox into an array.
What im trying to do when the button is pressed is:
Any ideas? (Note i only need help with the dumping of araay at this point
This is VB .net btw
Cheers Ona
Code:
Dim info As DirectoryInfo = New DirectoryInfo(saves)
CheckedListBox1.DataSource = info.GetFileSystemInfos()
- Dump Checked items to array
- Get Item number 0 (becuase arrays start at 0 yes?)
- Add string to item 0
- Then copy some crap using info gathered from string
- Uncheck Item 0 from list box
- Re dump checked items to array and loop cycle until no items left checked.
This is VB .net btw
Cheers Ona
