Clicks & Pops in Mic Audio due to buffer underruns. Please send help.
Mrayse
4 (0.08/day)
Hey everyone. Brand new here. I am at a complete loss. I have tried everything i can think of and i am not sure why more creators aren't talking about this.
I've seen this happen in a few people's streams as well lately but nobody seems to notice this. I made sure i checked the streams from my phone and my laptop as well to make sure the glitches were there.
I game at 4k120fps & record with OBS at 4k60fps.
The issue:
I'm experiencing some sort of intermittent digital glitch in my recordings during speech. Everything has been working flawlessly for 7 months when i first built my system, up until about a week ago.
There's like a short "click" or "pop" sound which seems to manifest randomly when i am speaking into the mic, not tied to plosives, clipping, or loudness.
If it helps, because I record with 2 audio tracks (gameplay + voice), the glitch happens in the microphone audio track. It can happen twice in a sentence, once, or not at all, but it usually happens.
Also it's worth mentioning that the speech quality is otherwise excellent.
Here's my setup:
Microphone: Shure SM7B
Interface: Vocaster One
Headphones: Sennheiser HD600
CPU: AMD Ryzen 7 7800X3D (stock settings)
GPU: NVIDIA RTX 4090
RAM: G.SKILL TRIDENT 64GB DDR5 (EXPO Enabled)
STORAGE: 2x Samsung 990 Pro SSDs (2TB)
OS: Windows 11 Pro (fully updated)
What I've already tried:
  • Tried with a new high quality, shielded USB-C to USB-A cable for the interface.
  • Tried connecting the interface to multiple rear USB ports on the motherboard.
  • Performed a clean reinstall of Vocaster Hub and drivers (including full registry/device cleanup).
  • Increased buffer size in the HUB from 192 to 256 samples.
  • Tested recording in OBS, and Audacity.
  • Not a live monitoring issue because i've muted hearing myself in Vocaster Hub.
  • Tested the SM7B with a different XLR cable — no change.
  • Clean Installed Latest NVIDIA Studio Drivers without NVIDIA HD Audio. (Was always using Game Ready ones until today)
    I've heard that newer NVIDIA Drivers increase DPC load, especially in combination with USB Interfaces.
    Some game developers also suggest that people with 40 series cards install driver versions that date toward the end of 2025 just before the 50 series launched.
  • Ran LatencyMon and you can see the results in the screenshots below.
I am just not knowledgeable at all when it comes to all of this, so what's my best course of action here? I don't understand why this is now a thing when it wasn't for 7-8 months.
This started manifesting while i was recording episodes for The First Berserker: Khazan which came out recently. It's not a very demanding game compared to some i was playing before that. (e.g. Monster Hunter Wilds).
Funnily enough when i was recording Monster Hunter episodes like a month ago, i didn't have that issue but it started with Khazan.
Rolled Back to Game Ready 566.36 NVIDIA Driver as The First Berserker Khazan suggested at some point if you are using a 40 series card, and this is the result from LatencyMon this time.
As far as i can tell the nvidia driver highest execution was 0.3ms before with the newer drivers, and 0.9ms with the rollback, so it's gotten worse for the nvidia driver but still not above 1ms.
The main problem seems to be wdf01000.sys. It has stayed pretty much the same.
The way i understand it, any value above 1ms (1000μs) is considered potentially disruptive for real-time audio so how do i lower that? and why has this gotten worse now?
Went back to Game Ready 572.83 NVIDIA Driver and updated BIOS to latest.
These are the new results from a lengthier test this time. Glitches very much still there. But there are like 4 drivers above 1ms now, and wdf1000.sys considerably reduced.
nvlddmkm.sys (nvidia gpu driver, kernel-level) -- 1.21ms
dxgkrnl.sys (direct x graphics kernel) -- 1.21ms
ntoskrnl.exe (windows kernel?) -- 1.1ms
ACPI.sys (power/thermal management?) -- almost 1.1ms
In the previous ones, the main offender seemed like it was wdf01000.sys
but in this one, it seems OK?
Anyone that knows what's happening here? I'm in despair mode...
4. I did a fresh install of OBS (cleared all settings too) and did another 15 min gameplay test session.
This is the first time latencymon gave me a green light and the latency seems normal.
Yet, OBS log still reports max audio buffering and the glitches are still there.
