cod warzone utilizes 50-55% cpu while bottlenecking gpu
Décsei Patrik
6 (0.00/day)
cpu: i5-10400f
gpu: rtx 2070
memory: 16gb 2133mhz
mb: gigabyte h410m s2h
psu: Cooler Master MWE Bronze 650W
So i don't have this problem in other games but in warzone my gpu is on 80-96% usage which i dont undersand because my cpu is only at 50-55%. So why my gpu usage is sometimes at 80%, when my cpu don't bottlenecks it? Why my cpu usage dont want to go any higher? is it because of my ram?(every component is new except my ram). My components are not overheating. If you want something else to know please let me know. Thanks for the answers.
dgianstefani
TPU Proofreader
5,490 (2.05/day)
Swansea, Wales
Benchmark Scores Legendary
Your CPU usage is threaded. So while you may only be using 55% of your multithread capability, you are probably using 100% of your singlethread, which is bottlenecking the GPU.
Décsei Patrik
6 (0.00/day)
Hi!
But i saw somebody in youtube with the same setup who had more cpu utilization(therefore didn't have any bottleneck). thats what i dont understand. but i will check cpu1,2,3,4..... in afterburner if thats the case. thanks.
1,211 (0.28/day)
Processor 11700
Motherboard TUF z590
Memory G.Skill 32gb 3600mhz
Video Card(s) ROG Vega 56
Case Deepcool
Power Supply RM 850
The problem with COD:Warzone is that it's very badly optimized it does not utilize cpu correctly and it also eats more ram then google chrome tabs.
Make sure that your draivers are updated, close all unnecessary software in the backround while playing cod you can also try scan and repair the game, there are many people out there with decent gaming pcs but just Warzone runs badly and that says everything.
Tatty_Two
Gone Fishing
26,030 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
Hi!
Same monitor resolution and refresh rate?
1,211 (0.28/day)
Processor 11700
Case Deepcool
Power Supply RM 850
its not the same monitor, just the same resolution.
Are your ingame video setting set correctly resolution and refresh rate for an example if you have an 1080p monitor 60hz your ingame settings should be 1920×1080 with 60hz refresh rate
570 (0.24/day)
PL, Krk (JPN, Tokyo)
System Name Nilin
Processor Ryzen 9 5800x
Motherboard Asus Rog Crosshair VIII Hero Wifi
Cooling Lian Li Galahad AIO 360
Memory G. Skill TridentZ Neo 32gb 3600Mhz CL16-16-16-36
Video Card(s) Asus TUF RTX 3080
Storage Samsung Evo 960 250gb (System), Samsung Evo 860 500gb (Misc), ADATA SX8200PNP (Games)
Display(s) LG 27" UHD IPS, LG Ultragear 27" WQHD Nano IPS
Case InWin 303 (7x Fractal Prisma 120mm)
Power Supply Tt Toughpower Grand RGB 850W
Mouse Razer Viper Ultimate
Keyboard SteelSeries Apex 3
Benchmark Scores https://www.3dmark.com/fs/21022952 (old system)
Why are we talking about bottlenecks?
Isn't it normal in games to use mainly GPU and some CPU?
Some titles might be more CPU heavy but still.
When its opposite, that's when bottleneck happens.
Décsei Patrik
6 (0.00/day)
games that mainly use gpu supposed to utilize 95-100%.
570 (0.24/day)
System Name Nilin
So long as You CPU is not at 99%, You are fine. No bottleneck.
Hows Your FPS? You get any freezes or something?
Décsei Patrik
6 (0.00/day)
no freezes, fps good. just conserns me the fact that the cpu is not nearly at 100 and therefore the gpu should be at 95-100%. Thats why i think its some kind of bottleneck. maybe my ram not fast enough.
570 (0.24/day)
System Name Nilin
no no, each system is different. software will behave differently, if your game works fine, why bother?
don't fix that which aint broken ;)
