COD went from gpu bound to CPU bound and running at 100%
IronBeast74
3 (0.01/day)
CPU running at 100% made no changes to the system.
Id someone has experienced this please give fix thank you in advance.
****NOW****
*****Before****
100% at the menu usually means it's doing a shader compilation in the background. Try re-doing the shader compilation process from the options menu and wait until it finishes.
There was no shader compilation! I usually wait till it is done to play.
every game it is 100% (CPU) usage and GPU used to be 100% but now it is not.
There should be a big update for the new season today so try it out later to see if it's fixed. It's not the first time the game gets broken.
Are other games working correctly?
That's what bots do..
****NOW****
*****Before****
What is your system specifications? That information could help out.
