- Sep 17, 2008
- 99 (0.02/day)
System Name | Blaznee's pc |
Processor | i7-4770k |
Motherboard | Asus Maximus VII Ranger |
Cooling | Noctua NH-U14S |
Memory | 16GB Kingston HyperX Beast DDR3 2400mhz |
Video Card(s) | Evga GTX980 Superclocked |
Storage | Samsung 840Pro 500GB, WD Black 1TB Sata6GB, WD Green 2TB Sata |
Display(s) | Acer Predator 34" G-Sync |
Case | Corsair Graphite 600D White edition |
Audio Device(s) | FiiO E18 Kunlun DAC |
Power Supply | NZXT Hale90 850w |
Software | Windows 10 |
Hi guys and gals,
Planning to build a new ITX based Coffee Lake gaming pc.
Due to space and girlfriend requirements, I'm trying to build small, quiet and nice. I have never build anything but full ATX builds, and it's been awhile.
So I'm pretty much going all in here.
CPU: 8700k
Motherboard: ASUS ROG Strix Z370i (possibly the MSI mini-atx z370 instead).
Memory: So here's the first one where I'm struggling.. With the 8700k cpu, is it better to utilize 4x DDR4 slots or not? Also.. I'm not a big OC'er, I usually just stick with whatever autooverclock the mobo gives me.. Should I aim for something above 2666mhz DDR4?
GPU: I'll just stick my 980 in it until Volta based ones come out. So it'll be full length
HDD's: If possible I'm sticking with just 2 Samsung 960 1TB NVMe drives. Are those bootable? Or do I need an normal SSD for that?
PSU: Depending on the case.. Anything Gold rated and above, pref. modular.. If the case requires SFX sized PSU, is this even possible with the above build? I max out at 600-650w with what's available to me with SFX sized PSU's..
Case: So I'm digging the In Win Gaming Cube A1 - but it's not near coming to market.. I need something small that fits a full size GPU.
CPU cooler: I prefer silent air cooling like Noctua.. But I'd like some recommendations fitting the cases you guys recommend..
As small and silent as possible..
CPU: 8700k
