CoH2 starts on wrong monitor
2,573 (0.38/day)
N.Ireland
Processor Core I5 4440 / 4430
Motherboard Asus z87-k / Gigabyte ga h97- d3h
Cooling Arctic freezer / Generic
Memory 8 gb Mushkin / Various
Video Card(s) Radeon 7850 cf / Gtx 690
Storage Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme
Display(s) Technika 32" / Asus 24` ips
Case Corsair
Audio Device(s) X-fi Titanium
Power Supply Corsair 850 w
I have a multi(2) monitor setup. I use 2 graphics cards, one for each monitor. Usually when I start up a game it plays on monitor1 card1 my main card. When I boot up CoH2 , however , it starts up on monitor2 a weak ass radeon 6450. I can work round it by disabling card 2 but this is a real PITA.
Anyone heard of this bug or got a suggestion to force the game to start on card no.1 ?
Things I,ve already tried
1. \dxadapter=0/1
2. -window. Works but the game won`t let you maximize it again
Steam says my graphics adapter is Radeon 6450...any way to switch this to the other card ?
Device manager says the radeon is graphics adapter no.1. Does this make a difference ?
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
Windows\Control Panel\All Control Panel Items\Display\Screen Resolution
Select - Display: [Monitor] attached to the adapter the game need to display on
Select - Make this my main display [put a tick in the box]
Select- Apply
or find the ini/xml file for CoH2 and edit the setting for the game
atb (all the best)
Law-II
2,573 (0.38/day)
N.Ireland
Case Corsair
Thx.
Display priorities already set..
I found the cfg file but no commands relating to adapter or monitor...
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
Thx. Display priorities already set.. I found the cfg file but no commands relating to adapter or monitor...
Ok, could try
-Power down the system switch off the PSU wait a couple of minutes and allow motherboard to drain of any charge or press the power switch while PSU is unplugged from the wall.
-Remove the Radeon 6450 vga card [*do not uninstall the driver]
-Power up the system
-Reinstall the game [*backup game save data; if not using the cloud]
-Delete ini/xml settings file #DriveLetter#:\Users\#UserName#\Documents\#Game Folder#!?
-Run the game and save settings
-Exit the game, shutdown windows
-Reinstall the Radeon 6450 vga card
-Next- Run the driver package for the vga card that the game needs to use
atb
Law-II
