- Jun 3, 2012
- 2,044 (0.43/day)
- Denmark
Motherboard | Giagbyte Z790 D AX |
Cooling | arctic freezer III 280 non argb |
Storage | 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives |
Display(s) | LG 32GP850, IIyama G2470HSU-B1 |
Case | Corsair 5000D airflow tg |
Audio Device(s) | Yamaha R-N800A System audio signature 5 + Audio pro addon sub 1 |
Power Supply | Corsair RM850X White |
Mouse | Asus Rog Gladius III Wireless Aimpoint |
Keyboard | Corsair K70 RGB TKL Champion |
Software | Windows 11 64 bit |
When i see youtube comparisons of cpu's they all test i 1080, alot in 1440 and a some in 4k
What they all have in common is they use a high end gpu 3070 ti, 3080 or something like a rx 6800 xt and always 1080 or higher to get as big a difference as possible (atleast in 1080)
When testing,comparing something like a ryzen 5 5600x or i5 10600k most wouldn't pair it with a + 1000 euro gpu like above a rx 6700 xt and rtx 3070/3070 ti to avoid not getting enough fps and background tasks that could decrease performance from a 6 core cpu's when gaming, in youtube videos they do use high end gpu's for something like an intel i5's and ryzen 5 cpu's
That's almost like getting as much fps as a higher tier cpu with a lower tier gpu, could be a i9 10850k + a rx 6700 xt vs a i5 10400f + a rx 6800 both might even cost the same since price difference between a rx 6700 xt and rx 6800 is high
A rx 6700 xt and rtx 3070 should be fine for a ryzen 5600x or i5 10600k but what if you want to se videos,result of lower tier gpus like rx 6600, 6600 xt,rx 5700 xt, rtx 2070, 3060, 3060 ti, how the performance would be both in avarage fps, 1% low and 0.1% low with different cpu's ranging from a ryzen 5 5600x, i5 10400f up to 10-16 core cpu's, theres is more or less none
Most can afford a high end cpu but going to a much faster gpu (rx 6600 xt, rtx 3060 ti) in these days, would be very expensive if you wanted a rx 6800 xt or rtx 3080, used ryzen 9 3900x would cost me less than 300-350 euros in my country, you couldn't get a used rx 5600 xt for that and only 350 euros would get me an rtx 2060 (price when selling a used rx 6600 xt or a rtx 3060 + 350 euros will still not get you a high end gpu) even if i wanted to i might be able to find an i9 10850k/10900k for 350 euros, which is high end even when ryzen 5 or 12 gen would be faster, it's still high end.
So is there any comparison of low/mid tier gpu's with higher end cpu's ? Most of us can afford a high end cpu (i9 10850k/10900k,ryzen 9 3900) but not a high end gpu (rx 6800 xt,rtx 3070 ti,3080)
Relase date for ryzen 7 5800x 3d cache, all i can find is spring 2022, what would the price be ?
