- Jul 9, 2016
- 1,088 (0.34/day)
System Name | Main System |
Processor | i9-10940x |
Motherboard | MSI X299 Xpower Gaming AC |
Cooling | Noctua NH-D15S + Second Fan |
Memory | G.Skill 64GB @3200MHz XMP |
Video Card(s) | ASUS Strix RTX 3090 24GB |
Storage | 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600; 2TB Samsung PM981a |
Display(s) | Dell U4320Q; LG 43MU79-B |
Case | Corsair A540 |
Audio Device(s) | Creative Lab SoundBlaster ZX-R |
Power Supply | EVGA G2 1300 |
Mouse | Logitech MK550 |
Keyboard | Corsair K95 Platinum XT Brown Switches |
Software | Windows 10 Pro |
Benchmark Scores | Cinebench R20 - 6910; FireStrike Ultra - 13241; TimeSpy Extreme - 10067; Port Royal - 13855 |
Hey all, I recently came across a problem that I am still baffled. I have built over 100 PCs for various people and reasons but have never seen anything like this. Perhaps my knowledge is wrong so it would be neat to learn something today.
I have a test machine that has been running without any issue. I recently decided to take the case, a nice Antec P280 for a different build with a larger motherboard, and move the test hardware to a Corsair 400R, a new case that is not used. After everything has been moved, I turned on the 400R. The CPU fans spun up, as well as the lights, DVD drive, GPU fan (a GTX 680) for a second and then the machine is off. I was puzzled as the test machine was running just fine previously. I proceeded to do all kinds of troubleshooting and finally, remove the motherboard and placed it on a test bench. Lo and behold it booted right up without any issue. At this point the only difference between the test bench and the Corsair 400R is the power supply and the case. I put the motherboard back into the 400R, and the same issue happened. I thought about replacing the power supply as it is getting old (a Silverstone Decathlon 800w). However, I thought the symptom of immediate shut off is reminiscing of a power "short", so with nothing else from the front panel connected, I used a screwdriver to "connect" the power pins of the motherboard, and lo and behold, it booted and posted!
At this point I figured the front panel power switch connector from the 400R is bad. I tried one more time but this time I reversed the polarity of the front panel power switch and again, the board booted up! So I figured, why not switch back to the previous polarity and see? Well, that didn't work!
My question is, and my understanding has always been, that the front panel power switch connector has no polarity. Its job is to "short" or connect the 2 power pins of the motherboard. This is similar to the reset switch, and unlike the HDD and power LED light that has + and - polarity. Am I wrong? What could be the problem with the 400R?
Since I switched the "polarity", the 400R has been running fine, turn on and off without any issues.
