Computer not booting when system fan plug is connected
125 (0.03/day)
System Name ummm... haven't decided yet :P
Processor i3 3220
Motherboard Gigabyte GA-H61M-S
Memory 2x 4GB DDR3
Video Card(s) Galaxy GT730 1GB DDR5
Storage Toshiba DT01ACA050 500GB, WD 120GB IDE and Samsung 750 EVO SSD
Display(s) BenQ VL2040AZ 19.5inch
Case HCL ATX Mini
Power Supply Corsair VS450
Mouse Microsoft Basic Optical Mouse 2.0
Keyboard Amkette Black Multimedia keyboard RX3 USB
So i just got a new PSU for my old build and surprisingly when i connect the 4pin plug for the system fan, pc doesnt boot!
On removing just this one plug, it boots
Why is this happening ?
For specs, check my profile, its fully updated.
PS guys if i leave the system fan(dont attach it) what will happen ?
18,584 (2.64/day)
System Name AlderLake
What if you connect the system fan to another system fan header?
Motherboards nowadays have more than one system fan headers.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Bad fan
But go into the bios and change the fan speed settings. See if that helps
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
First try a different fan, maybe a 3-pin.
Although the system fan header has a 4 pin, it might only accept 3 pin fans. There are settings in the BIOS specifically for the system fan, for which header idk, it might have one for each header, just make sure its not disabled or off.
125 (0.03/day)
Processor i3 3220
Memory 2x 4GB DDR3
Case HCL ATX Mini
No guys Im not talking about any external fan.
My gigabyte mobo has 4 pins coming out of it, next to those pins is written "sys_Fan".
When I connect my mobo's connector on those pins, pc doesn't boot.
Whereas in my old psu i did the same and the pc always booted
18,584 (2.64/day)
But you are connecting a fan to that "sys_fan" connector aren't you?
I don't get this part:
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Are you talking about the 4 pin ATX connector for the CPU?
13,942 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
What?
You don't connect your power supply to those pins! Is that what you are doing? If so, you might just destroy your motherboard!
You connect the system fan (typically the chipset fan) to the pins labeled Sys_fan. Those pins deliver power to fan. Those pins get power through the motherboard already.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Your PSU comes with a 4+4 pin ATX/EPS12V CPU power connector. Make sure you're using the correct set. If it took a lot of force to plug it in, that might indicate that you're using the wrong set of 4. And/or in the wrong orientation.
13,942 (2.04/day)
Nebraska, USA
Mouse Logitech M190
I agree with thebluebumblebee but again, you do NOT connect any cable from the power supply to any header on the motherboard labeled "fan" - that includes "Sys_fan" which is what the OP referred to.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
The SYS_FAN, CPU_FAN and 4 pin ATX/EPS12V CPU power connector are bunched together on his system. SYS_FAN may be all he's able to read while it's in the case.
13,942 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Excellent point but all the more reason to ensure he is not connecting a power cable the fan header. I note the 4-pin ATX connector has the pins arranged in a square and is typically a socket. Fan headers are "headers" that is, typically just pins sticking up and in the case of fans the pins are arranged 3 or 4 in a line, not a square.
Plus (I hate to assume, but...) assuming the motherboard in question is the one listed in his System Specs, as seen here, as you noted the 2 fan headers and the 4-pin ATX connector are clustered together, but are clearly labeled.
So before assuming anything else, I think we need clarification from the OP.
125 (0.03/day)
Processor i3 3220
Memory 2x 4GB DDR3
Case HCL ATX Mini
Im myself confused after reading all the answers lol
Billbright has got it right, im talking about 4 pin lines under which it reads sys_fan
You know like for attaching front speakers there are pins emerging out of the mobo, just like it sys_fan pins are there.
While using my old psu, i use to connect the '4 pin taker' plug( :D) to those sys_fan pins and everything use to work flawlessly but now on doing the same it doesn't :/
But i left those pins undisturbed and used the PC for few hours without any problem.
If they aren't meant to be attached to their respective connector from the PSU, then i wonder how my previous psu worked fine ?
842 (0.18/day)
Germany
System Name Perf/price king /w focus on low noise and TDP
Processor Intel Xeon E3-1230 v2
Motherboard Gigabyte GA-B75M-D3H
Cooling Thermalright HR-02 Macho Rev.A (BW)
Memory 16GB Corsair Vengeance LP Black
Video Card(s) Gigabyte GTX 670 OC
Storage 525GB Crucial MX300 & 256GB Samsung 830 Series
Display(s) Home: LG 29UB65-P & Work: LG 34UB88-B
Case Fractal Design Arc Mini
Audio Device(s) Asus Xonar Essence STX /w Sennheiser HD 598
Power Supply be quiet! Straight Power CM E9 80+ Gold 480W
Mouse Roccat Kone XTD optical
Keyboard SteelSeries Apex M500
Software Win10
Only the MoBo itself and the CPU need power from the PSU. Then the MoBo powers the sys_fan and the other fan headers all by itself - do not connect your PSU to any of those headers.
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Don't even tell me that you're connecting a FDD power connector to that fan header. Oy......:wtf:
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
The fan header is 4 pins in a row. The 4 pin ATX/EPS12V CPU power connector is 2x2, or square. Like this:
But your PSU comes with a 4+4 pin ATX/EPS12V CPU power connector that looks like this:
Can you see how they are "keyed"? You want to use the one from the pair that's keyed like the single one above
Which looks like this:
13,942 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Well, and many graphics cards, and of course, drives. And you can power case fans directly from the PSU too, but you won't get any monitoring or automatic speed control that way.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
please take pictures of what you're plugging in, and where you're plugging it in.
125 (0.03/day)
Processor i3 3220
Memory 2x 4GB DDR3
Case HCL ATX Mini
The last pic attached by @mrbluebumblebee is the connector I I'm talking about and the pins that emerge from the mobo are the perfect fit for it.
dorsetknob
9,106 (1.24/day)
As Said by others
DO NOT CONNECT ANY Cable from your PSU to the sys header pins
POWER FROM YOUR PSU TO THE CORRECT MOTHERBOARD (atx 20+4 AND CPU 4 ) CONNECTORS
YOUR FANS TAKE POWER FROM THE MOTHERBOARD NOT YOUR PSU
caps because you need to take notice of this
2,100 (0.47/day)
Spencerport NY
System Name Master
That doesn't mean you just blindly plug it in there.
Jesus.
You're lucky you still have a running rig.
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Wow, just wow. :banghead:
Mussels
58,412 (7.78/day)
Oystralia
heres a pic of the fan connector on your motherboard, and yeah if you jammed a floppy power cable onto that you're lucky you didn't start a fire :/
397 (0.08/day)
System Name potato
Processor Ryzen 9 5950X
Cooling Custom WC Loop
Memory 2x16GB G.Skill Trident Z Neo 3600
Video Card(s) RTX3090
Storage 512GB, 2TB NVMe + 2TB SATA || 32TB spinning rust
Display(s) XIAOMI Curved 34" 144Hz UWQHD
Case be quiet dark base pro 900
Audio Device(s) Edifier R1800T, Logitech G733
Mouse Logitech G Pro
Keyboard Logitech G913
Software win 11 amd64
Frick
Fishfaced Nincompoop
20,050 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Keyboard Dell SK3205
It's not even 8 in the morning and already my day has been made. :roll:
Attach a fan to it and see if it works. If it doesn't, you've killed something.
