Connecting VGA laptop to DisplayPort/HDMI Monitor?
3 (0.00/day)
Hi there.
I just got this Dell UltraSharp U2414H and stupidly enough I didnt check whether it has VGA, which is the only output my laptop supports. It's not a problem for my desktop, with using HDMI but I'd like to connect my laptop sometimes as well.
I see these cables that allows for connecting a VGA Monitor to a DP source but isn't it possible to do the opposite without some insanely expensive converter?
Thanks
22,160 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
No. You will need an active converter. HDMI/display port don't cary analog signals like old DVI did.
3 (0.00/day)
Hm.. right.
I seem to be pretty terrible at googling for these things.
I don't suppose there's some "all"-in-one converter that maybe also includes composite signal just for the heck of it, with then can be connected to DP or HDMI?
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
1,463 (0.31/day)
Processor i7-13700k (undervolts -0.140 volts)
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Monoprice sells a couple vga to HDMI box's for about same price.
