Connection Problem
Scythez0r
60 (0.01/day)
New Zealand
Processor AMD Athlon 64 X2 4000+ @ 2.1GHz
Motherboard ASUS M2N-X nForce 520
Cooling Front 120x25mm Blue LED x1, Rear 120x25mm x1, Left 120x25mm x1 (Case Stock)
Memory Kingston (2x1GB) DDR2-667 CL5 Dual Channel
Video Card(s) Sapphire Radeon HD 2600XT 256MB GDDR3 @ 800/1400
Storage Seagate Barracuda 320GB 7200.10 16MB SATA2
Display(s) Acer AL2016W LCD @ 1680x1050 60Hz
Case Cooler Master Chassis CM 690
Audio Device(s) Onboard HD
Power Supply Silverstone Strider ST400 400Watt
Software Windows Vista Ultimate SP1, PS CS3, Loads of Games =D
Hey guys, got me a new Modem not long ago and recently plugged it in, seemed to be working fine at first but every now and then something happens and it seems to disconnect. It says its still connected and everything and going into status it says it's connected fine, it seems to just stop for a while then comes back on after awhile. Unplugging and Rebooting it does nothing.
I know its the Modem because I had a different modem plugged in before and it was fine. It is a Belkin f5d5730au and is connected to a CNet CNAP-711 11mbps Wireless Router. Also, when another computer is turned on, it doesn't seem to allow it to connect for a small while then works.
Any ideas? This is really annoying...
