Casheti
I can't seem to connect to rapidshare.com sometimes and if I ever manage to actually get to it my downloads don't go anywhere near full speed. I'm lucky if I get 60kb/s. It used to go 240kb/s.
What's going on?
Processor | AMD 64bit - Dual-Core 4200+X2 at 2.64GHz 24/7 |
Motherboard | ASUS A8n-SLi Deluxe |
Cooling | Zalman AB3CL CPU Cooler with 12Cm Fan, Plus 10 Fans at 12CM lol |
Memory | 2GB DDR 400MHz 3-3-3-8 |
Video Card(s) | BFG 7900GTX OC - " My Big F'N Gun " |
Storage | 1 x 250GB WD Caviar RE SATA-300, 1 x 250GB Maxtor IDE, 1 x 160GB Samsung Spinpoint |
Display(s) | 17 " Hansol TFT LCD |
Case | Thermaltake Kandalf VA9000SWA - Aluminium Full Tower Case |
Audio Device(s) | On-board 7.1 |
Power Supply | 650WAtt Atrix |
Software | Vista Business |
I can't seem to connect to rapidshare.com sometimes and if I ever manage to actually get to it my downloads don't go anywhere near full speed. I'm lucky if I get 60kb/s. It used to go 240kb/s.What's going on?
I have a work around if anybody is interested.
This work around only applies if you have the link to the file your are trying to get, for example the http:// code.
All rapidshare links look like this: http://rapidshare.com/files/????/?????
What you simply do if you are having connection issues like I do, Rapidshare always comes up with "Internal Server Error 500" for me or it times out so what I do is this,
You simply type the first part of the code like this: http://rs240.rapidshare.com/files/
after /files/ you put the rest of your code to your file usually numbers forward slash then another series of numbers or letters or a combination thereof.
This is simply a direct way of getting to the file you want without going through the website and clicking free user or premium user. This work around has been working for me and I hope it helps you.
Improvised
