Cons of using System Builder oem versions of Windows 7?
Emanon Retsim
13 (0.00/day)
Heyas folks I'm getting ready to build a new computer and I'm thinking about using windows 7. Are there any cons to using the system builder oem versions of
Windows 7 for myself as oppose to using a consumer upgrade version?
2,190 (0.36/day)
Minnesota, USA
System Name TaichiTig
Processor i7 6800K
Motherboard ASRock X99 Taichi
Memory 32GB DDR4 3200
Video Card(s) RTX 4070
Storage SSD + Misc. HDDs in DrivePool
Display(s) BenQ PD3200U, Samsung C32HG70
Case Antec Twelve Hundred
Audio Device(s) Behringer UMC404HD, LSR308, Shure SRH840, AKG K612, Etymotic HF5
Power Supply Corsair 750TX
Keyboard Deck Legend Ice Tactile
Software Win10
The system builder version is restricted to clean and custom installs. No upgrades. Also, it is licensed for only one computer for life (locked to motherboard) whereas otherwise it would be one computer "at a time."
926 (0.15/day)
Akron, OH
System Name Main Rig
Processor Athlon 5350
Motherboard AsRock mITX
Memory 4gb
Storage 120gb Kingston HyperX SSD
Display(s) Samsung Syncmaster 740N
Power Supply Corsair 430 watt
Right. "Locked to the motherboard" is probably the best way to describe it. For the most part, MS won't give you hassle if you upgrade the RAM, or the hard drive, or the video card, or the CPU, but changing the motherboard could very well land you without the ability to activate your OEM copy any more.
375 (0.06/day)
United Kingdom / Poland
System Name FlowTI
Motherboard MSI MAG B650 TOMAHAWK WIFI
Cooling Arctic Liquid Freezer II 240 RGB
Memory Corsair Vengeance DDR5 32GB 6000MHz/CL30 RGB
Video Card(s) Gainward GeForce RTX 4070 Ti
Storage Main: Crucial P5 Plus 1TB | Data: Crucial P3 Plus 4TB
Display(s) DELL S2721DGFA 165Hz
Case NZXT H5 Flow RGB
Audio Device(s) Audioquest Firefly Black DAC | Beyerdynamic DT 700 PRO X | Shure MV7 Microphone
Mouse Logitech Pro X Superlight
Keyboard Logitech MX Keys
Benchmark Scores Don't care
Most of times all you have to do is call them during activation and tell them that you had to change the motherboard because it died (or something like that).
The main problem would be the sticker. Your OEM is legal as long as you have the sticker with serial number on the computer. And they are pain in the ass to unstuck if you'd like to switch cases.
2,047 (0.36/day)
Republic of Texas
Processor R9 5950x
Motherboard Asus x570 Crosshair VIII Formula
Cooling EK 360mm AIO D-RGB
Memory G.Skill Trident Z Neo 2x16gb (CL16@3800MHz)
Video Card(s) PNY GeForce RTX 3090 24GB
Storage Samsung 970 EVO Plus 1TB NVMe | Intel 660p 2TB NVMe
Display(s) Acer Predator XB323QK 4K 144Hz
Case Corsair 5000D Airflow
Audio Device(s) Objective2 Amp/DAC | GoXLR | AKG K612PRO | Beyerdynamic DT880| Rode Pod Mic
Power Supply Corsair AX 850w
Mouse Razer DeathAdder Elite V2
Keyboard Corsair K95 Platinum RGB "Cherry MX Brown"
VR HMD Oculus Rift
Software Window 11 Pro
dunno bout win7 but when i had vista i have change MB mutiple times and i just called MS and got it activated again
+1
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
+1
Yes, that works, but it is not legal...
SummerDays
276 (0.05/day)
At $100, the OEM version of Windows 7 makes more sense than the full or upgrade versions, unless you need technical support from Microsoft.
What a joke needing a sticker on your computer in order to have a legal copy.
2,047 (0.36/day)
Republic of Texas
Processor R9 5950x
VR HMD Oculus Rift
2,190 (0.36/day)
Minnesota, USA
Processor i7 6800K
Software Win10
That's correct. Legally you can replace the motherboard if the original fails, but if you replace it for an upgrade, Microsoft considers the computer to now be a new, separate system requiring another license.
They don't have a way to stop you from upgrading and saying the new motherboard was a repair, though.
375 (0.06/day)
System Name FlowTI
Last time I've changed my motherboard it was from Socket 754 to LGA775.
Socket 754 dude! It hasn't failed. It WAS a fail. :laugh:
EDIT:
Windows 7 is the first OS that can make me buy a BOX license though. We'll see.
1,203 (0.17/day)
FL
System Name Iam-a-computah
Processor i9 9900k @5 Ghz
Motherboard Gigabyte Auros z390x
Cooling Custom water loop, x2 280 radiators
Memory 16gb Corsair Dominator
Video Card(s) MSI 1080 TI FE 11gb WC
Storage SSD: 256gb Samsung 840pro & HHD: WD black 2T
Display(s) LG 34" UW screen
Case EVGA DG-86
Audio Device(s) Creative x-FI
Power Supply EVGA super NOVA 1300wtt
Keyboard G710
Software W 10
There so many ways to fool the Ms ppl is not even funny. I remember having lisencig problem due to the fact that you can install the OEM version just so many times [around 4, in same pc..vista anyways] and I just called up the automated system, gave them some code and boila new again, sometimes I had to talk to someone. Because my key wouldt work sometimes so instead of remotly controlling my pc to fix the lincese, they just. Gave me a new one....which was pretty much a whole new key. I ended up with 3 new licenses and just to mind you, all this happened by chance I didn't had anything planned. I just wanted to play TF2 But. Comes to show that oem is not that bad. You just gotta deal with MS to get stuff sorted out.
-excuse my grmmar I typed on my phone in a moving bus =p
Solaris17
Super Dainty Moderator
27,596 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
how is that illegal? if i bought one of these and installed it on my system and then got classified as opposed to a vanilla X58 and call to get it reactivated how is it illegal? why else would they call it "system builder" do they somehow not expect us to switch mobo's? not calling you out i dont doubt it. i dont buy OEM for the sole reason that is i dont want to call everytime i reinstall. im just curious.
unless im reading this on the wrong freq and system builders pertains to DELL and compaq and not to indaviduals with alot of money to blow.
2,190 (0.36/day)
Minnesota, USA
Processor i7 6800K
Software Win10
Solaris, "System Builder" refers to building/integrating systems for others professionally, not putting together your own system as a hobbyist. According to the EULA, it is, in fact illegal to use the same license after a motherboard upgrade. Like I said above in this topic, if you replace the motherboard for an upgrade (as opposed to for a repair), Microsoft considers the computer to now be a new, separate system requiring another license.
Solaris17
27,596 (3.84/day)
Alabama
VR HMD Quest 3
iv been
:slap:
INFORMED
thanks :toast:
Bot
594 (0.10/day)
System Name BoTBlue
Processor Intel i7-3770
Motherboard Intel DQ77MK
Cooling Corsair H80
Memory Samsung 4x4Gb
Video Card(s) ASUS GTX 470
Storage OCZ Vertex LE
Display(s) Acer
Case AthenaTech
Power Supply Corsair 850w
Software Win 7 Pro x64
MS is only concerned and interested in that this license is only installed and active on one single computer. no matter the mobo or if you upgraded or use it on a completely different system.
there have been times were i had to re-activate my license because i changed ram and/or cpu only.
any "major" hardware upgrade will require a re-activation and they will only ask you if the license is installed on only one computer.
375 (0.06/day)
System Name FlowTI
Yes Bot, you are true about MS being concerned and interested only in that. And sure, you can practically activate license as many times as you want (which I was doing quite a lot of times already), but as Solaris17 said - it's still against the EULA.
Being able to activate an OS is one thing but following EULA is another. :p
1,050 (0.16/day)
indiana
Processor c2d e8400@ 3.8ghz 24/7
Motherboard Abit IP-35e 80$ lol
Cooling zalman cnps9700 led
Memory 2 x 2 gig patriot viper
Video Card(s) evga Gtx 285 oc
Storage 2 x 300gig sata seagate 7200.10 in raid 0/ 1.5TB for backup
Display(s) acer 24" TFT LCD AL2416WBSD
Case Antec 902
Audio Device(s) XtremeGamer Fatal1ty Pro series
Power Supply ocz gamextreme 700w
Software windows 7 ultimate
If they let you do it its LEGAL....... PERIOD :toast:
Fourstaff
10,089 (1.79/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
+1 on that, sometimes I think Microsoft feels guilty and let us upgrade and count it as replacement, which is good.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
You have to call them and explain to them why you are reinstalling it on a different system (e.g. mainboard died). The only important thing they are looking for is that the license is not installed on two separate computers at any given time.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
The only problem with that logic is that you have LIE to get them to re-activate it. You have to tell them your motherboard died, if you tell them you are installing it on a new computer because you upgraded, they will not re-activate, try telling them the truth sometime and see what happens.
They don't let you do it, they simply don't question what you tell them and assume you are telling the truth. By lying, you are not only breaking the EULA, but I'm pretty sure there is some kind of fraud issue there as well.
That is what they are looking for with the Retail copies, with the OEM copies the important thing they are looking for is that it isn't being installed on any other computer than the original computer it was installed on.
Bot
594 (0.10/day)
System Name BoTBlue
Cooling Corsair H80
Display(s) Acer
Case AthenaTech
when i call it's usually an automated voice prompt.
asks for the numbers i have, gives me the numbers i need and asks if this installed on more then one computer.
nothing else, no lie's, no half truth's, no hassle
EastCoasthandle
6,885 (0.94/day)
System Name MY PC
Processor E8400 @ 3.80Ghz > Q9650 3.60Ghz
Motherboard Maximus Formula
Cooling D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB
Memory XMS 8500C5D @ 1066MHz
Video Card(s) HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean)
Storage 2
Display(s) 24"
Case P180
Audio Device(s) X-fi Plantinum
Power Supply Silencer 750
Software XP Pro SP3 to Windows 7
Benchmark Scores This varies from one driver to another.
This is correct folks. I've used it myself and this is what they inform you of.
1,168 (0.20/day)
Austria, Europe
System Name Bang4Buck
Processor AMD Ryzen 9 5900x
Motherboard MSI PRESTIGE x570 CREATION
Cooling Fractal Design Celsius S36
Memory 32Gb 4400Mhz Patriot Viper Steel(Samsung B-die) @ 3800Mhz 16-16-16-32-48-1T @ 1.38v
Video Card(s) MSI RTX 3080 Ti Suprim X
Storage Adata SX8200Pro 512Gb/2x Crucial P1 1Tb/Samsung 840 EVO/6Tb Raid -HGST Enterprise/2x IronWolf 8Tb/
Display(s) Samsung UE49KS8002 4K HDR TV (US - 9 series)
Case Fractal Design Define R6 Black Usb-C
Audio Device(s) HDMI out to Denon X4400H reciever, 2x Dali Zensor 7, Dali Zensor Vokal, 2x Dali Zensor 1, Yamaha Sub
Power Supply Seasonic Prime Ultra 750W
Mouse Logitech G305 Lightspeed
Keyboard Logitech K520
Software Windows 11 Pro x64
Benchmark Scores https://www.3dmark.com/spy/26216445
Mister Noname, hmmm nice one. ;)
Fourstaff
10,089 (1.79/day)
Home
Well, you can always not lie and destroy the mobo on purpose. I suppose that will sooth your guilty conscience.
