Contrast Ratio VS Dynamic Contrast Ratio
1,197 (0.20/day)
Asia, PH
Processor Q6600 @ 3.6GHz | P4 @ 2.1GHz
Motherboard Asus Commando ROG (Vdroop mod) | Asus P4V8X-MX
Cooling MegaShadow w/ 2x Scythe Slipstream MX-2 Paste + Kama Bay + 4x120mm case fan | stock Intel
Memory Kingston 4x1GB DDR2 @ 800MHz w/ OCZ XTC cooler | 1GB DDR @ 400MHz
Video Card(s) Palit GTX 260 1792mb 448bit @ 713/1458/1116x2 | GeForce 4 MX 440 AGP8X 64mb 64bit
Storage 640GB WD AACS 250GB Excelstor 160GB Seagate | 40GB WD
Display(s) Samsung T220, Samsung 32" 1080P | LG L1752S
Case Gigabyte 3D Aurora 570 | Trendsonic mid tower
Audio Device(s) Asus Supreme FX (Creative Inspire 5.1 speaker), Samsung HT-Z220 | Onboard audio (2.1 Speaker)
Power Supply Gigabyte Odin Pro 800W | 550W generic
Software Vista Ultimate 64 SP2 | XP Pro 32 SP3
Benchmark Scores 3Dmark06 - 17,348 Vantage - P13,510 Super PI 1M - 12.765s @ 4.1GHz GenericCPUbench - 6,864 ms 38,
Depends, typically Dynamic simply brightens the screen and over-saturates things, creating brighter whites. Watching movies, or if the dynamic gets up to 50,000:1 or so, your not going to want it on, as it doesn't provide as natural color, or it's too bright (in a dim room at least). However, in my experience w/ computing I would usually rather have it on during games and most things, as you don't really need perfectly accurate color reproduction (and won't really get it anyway) and it looks better that way. 4000:1 isn't that high anyway so it won't hurt your eyes, and the normal cr is probably around the first one (1000:1 or so), so I would go w/ that one (#2 out of the 2).
so should I get the one with 1200:1 CR?
Based on cr alone I would go w/ the 4000:1 dynamic, as its regular is probably around 1200:1 and the dynamic is better for gaming (although really the 1200:1 probably has dynamic as well and is pretty close to the other).
Do not buy Chimei screens they utterly suck. Never seen so many screens with dead pixels or other hardware errors.
Yeah I was wondering about the brand, never heard of em. I've found screens (tvs and monitors) are generally some of the things where you want to go w/ a name brand, the no-names will burn you or simply not be very good.
what are the good/best brands of LCD monitors?
It depends on the panel it uses. TN is the most common for non-professional monitors suited for the mainstream. For most, it's the most affordable too. I really like Samsung as far as manufacturers go. As far as getting the best quality out of a TN panel, look for things like a smaller pixel pitch, and read reviews. While many manufacturers can use the same panel, the monitor itself can be built differently having an effect on quality. Acer, Samsung, BenQ and a couple others all make some good monitors.
Asus, Samsung, and BenQ are the best ones I can think of. Definitely read reviews about them before you buy.
I love my 22" Samsung.
