I want to remove a 3.5 inch internal hard drive from a problematic (dying) desktop and use it as an external backup for a different PC via a USB 2 connection. How do I prepare this hard drive for removal and re-use?
My (few) friends frequently tell me that I know only enough to be dangerous. You folks are apparently very knowledgeable individuals, and I would very much appreciate any assistance you can provide. Perhaps you could just point me in the right direction for reference material, tutorials, etc.
The hard drive in question is a 100GB Seagate ST3100011A (Barracuda 7200.7). According to Seagate's instructions on how to interpret their model numbers, the drive has a 2MB cache and an ATA (IDE?) interface.
I've found a fairly highly-rated external enclosure (Rosewill RX355-U) from a reputable retailer that seems to fit my needs, but I am open to any alternatives you might suggest.
I am completely ignorant as to what I need to do to the hard drive before removal from its sick host. Caches, partitions and the like are totally Greek to me.
I assume the Windows XP operating system installed on the drive will have to be removed at some point in the process, but there is data on the drive that I would like to preserve if possible. The PC for which the hard drive will serve as a backup is running Windows 7.
