Cooler Master Stack Cross flow fan
freaksavior
To infinity ... and beyond!
8,095 (1.20/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
I think it might replace the 4 x 120mm fans on the side panel...
with just that? i don't understand how that would work!
it fits in a special place at the right of the case,and blows air towards the motherboard,i believe.
like this-
would it be better than 4 of these?
Newegg has it for $25.00 not a bad deal really, seems like a good idea. Would be nice if they had something like that in a HTPC case, one intake across the front top and a output across the back bottom.
edit: reverse that
so would it be worth getting then?
if you have the dosh,why not.looks like it will blow cool air onto your ram.
I would think that depends on the layout of your board and cables. The air blowing over it like that should in most cases cool your chipsets/ram better and my direct some air under the mobo to cool the backside.
from the reviews on newegg, it sounds like a waste of $$
With the sdie panel fans on a Stacker, trust me when I say, you want a slightly more silent fan than the ones you have chosen. With the mesh on the side, all the noise easily escapes.
I have 4 Scythe S-Flex 33.5cfm 8.7dBA fans in my Stacker side panel, and the airflow is more than enough, when used with higher flowing fans in the rest of the case. They made a huge difference in overall noise output, compared to the 22dBA(ish) fans I had in there previously, but very little reduction in cooling performance.
I have no experience with the crossflow fan, but if you set up your 120mm fans properly, I see little benefit to having one.
hmm, yeah didn't think about that. 12 120mm @ fans 21db each. it would sound like a train! :laugh:
you can use them as well as the cross flow fan.
that is in correct you can either use all 4 120s or 2 120s and the crossflow fan basically
120|120
120|120 or
120|crossflow
120|crossflow
