Cooler touching ram
diddle
77 (0.01/day)
System Name Diddulator
Processor AMD x2 5000+ @ 3.12 ghz, 1.280V
Motherboard Biostar TF720 A2+ (fail..)
Cooling Stock Heatsink, 2 x 200mm fans, 2x 120mm fans
Memory 2x1 GB Gskill PC2-6400 @ 445.7mhz
Video Card(s) Sapphire 3850 512mb stock :669/829 running at : 776/1008
Storage 500 Gig IDE
Display(s) 17 inch LCD @ 1280x1024
Case Thermaltake
Audio Device(s) Sound Blaster Live 5.1
Power Supply Raidmax RX-530SS 530watt 37amp rail
Software Windows XP x86
Benchmark Scores 3DMarks06 - 10200
I'm looking to purchase a Core Contact Cooler and my ram is basically right next to my CPU.
Is there any chance at the new CPU cooler interfering with my DIMM slots? This is a picture of my mobo.
Biostar TF720
In essence, you shouldn't have a problem however it depends on the height of your ram and the height of the cooler where the fins stick out. Worst case scenario you could always cut a couple of the fins off the cpu cooler. Are you using 2 or 4 gigs of RAM?
System specs say 2, so you could always just use the outer two slots and still have dual channel.
it depends, if u have the gskill not pi wich features standard sized heatspreaders there shouldnt be any problem as the core contact is a tall heatsink
Well the fan that you put on the side is usually oriented to blow the heat out of the back case fan, and if thats the way you configure this, then the cooler should be parallel with the ram and not have any problems. The fan that you stick on might, but you can always work around that and shouldn't be a problem. Should be fine.
I've got the core contact. The heatsink itself doesn't interfere at all with my ram, but the fan sits on top of the first dimm slot. However than is OK because the core contact's fan is held on by 2 wire clips so you can slide the fan up away from the ram giving you room to remove it if you need to.
